Wisconsin Engines
Wisconsin V4 wire placement (magneto)
this thread has 2 replies and has been viewed 851 times
Old 11-23-2016, 04:44:49 PM
q930 q930 is offline
Default Wisconsin V4 wire placement (magneto)
I need to know the plug wires placement on the mag distributor cap. Before I took them off I wrote them down, but in the course of daily living, it has disappeared. It's a Wico but sure it's the same for a F-M. I know the firing order is 1-3-4-2 and rotor goes CCW. Just need to know where #1 wire goes. Thanks
Old 11-23-2016, 06:46:09 PM
Arlie Levy Arlie Levy is offline
Default Re: Wisconsin V4 wire placement (magneto)
It would be the front cylinder that is further forward then the other. The cylinders are not straight across from each other.
Old 11-23-2016, 09:48:18 PM
Your shop manual will show it if you look it up as we don't know your model and type number.
Here's a diagram. But we don't know if you have a CCW or CW magneto rotation. Sentence 1 sez it all. Get it wrong and you'll have a lot of noisy burping, and a nice light show from the air cleaner and exhaust.
magneto charger wire source a jossund Magnetos, Ignition Coils and Spark Plugs 4 02-21-2015 03:23:36 PM
A-C magneto plug wire boots mdtractormechanic Magnetos, Ignition Coils and Spark Plugs 4 12-31-2014 06:43:26 PM
Magneto wire bracket source mag473 Magnetos, Ignition Coils and Spark Plugs 1 12-20-2014 10:38:27 PM
plug wire wico ek magneto jdrj4 Magnetos, Ignition Coils and Spark Plugs 2 06-20-2011 08:10:39 PM
Replacing plug wire on Elkhart Magneto. HELP!! Daniel Dorece Antique Gas Engine Discussion 5 03-03-2008 11:41:01 PM
