this thread has 4849 replies and has been viewed 321182 times
Old 07-18-2015, 09:57:48 PM
Default Re: What have you done to your Onan generator today?
pic of the condensation around the carb.. my old vw with twin webers use to do this when it was humid or cold
ID:	230009   Click image for larger version
Old 07-19-2015, 01:03:04 PM
len k len k is offline
Started up my 7NHM to exercise it. Was real humid , carb was sweating too. Would expect this of any carb not warmed by engine (long intake).
Ethanol gas finally caught up with me. Today I also started my car across the street to exercise it, car has been parked for few years. I only start car every 3-6 months. Warmed it up. Drove it up and down the street, then floored it to exercise all the transition gears, it stalled out. Turns out gas pump in tank died again, just replaced it ~ 1-2 years ago. Pump was running then nothing, even applying 12V to pump wires. Draws current but doesn't turn. Hammering tank and reversing polarity didn't clear it. Guess I have to drop tank again.
Humm I wonder if quickly applying 24 V will jar it free? I suspect fuel/air ratio in tank is too high to ignite even if there's a spark.
Old 07-19-2015, 02:04:30 PM
Let us know how the 24volts works!
Old 07-19-2015, 02:09:32 PM
Myth Busters tv show even fired tracer rounds into a gas tank and it didn't explode, gas only ignited AFTER it leaked out of tank holes. Suppose I should first test that no spark ignition theory with a coffee can, and a small piece of glass/plastic for a gravity lid.
Old 07-19-2015, 02:40:12 PM
BigBlockChev's Avatar
I would suggest trying 12V with a bit of percussive maintenance applied while it is powered up, it may break free. Or just pull the tank and take it out, the easy way is the hard way. Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
Old 07-19-2015, 02:46:53 PM
I did whack plastic tank with a good sized rubber hammer, pump powered up and unpowered .....no change. I can try whacking it reverse powered. When I disassembled bad pump 2 years ago it had rust spanning rotor/stator gap.
Old 07-19-2015, 03:07:51 PM
you might be able to hook up a secondary fuel pump to pump the old fuel out.. what kind of car is it?
I wouldn't worry about it blowing up.. I mean if it does you wont have to worry about it, most likely.. when I drove tow trucks we did the rubber mallet smack on the gas tank and sometimes it worked..
Old 07-19-2015, 03:31:12 PM
92 Chev caprice.
I'ld rather just drop the tank and replace it. Pretty simple, not much to it, just a pain. Guess I have to start it more often to keep it from rusting. Gotta drain the old gas and try stabilizer and new gas . after I put in new pump.
About a month ago on the 93 caprice I replaced same pump. Took pump off my Onan NHM and pumped 15 gallons between cars in 50 minutes. got it all out too. There's a in tank ~ 8" box shield around pump and float sending unit so you can't bend them with a siphon hose.
Old 07-19-2015, 04:38:17 PM
Hammer usually works on starter motors...... for a week.
THE FLAME TEST... ahh now the fun starts.
Took a coffee can and made a hi-voltage feed thru. Punched ~ 3/8 dia hole in can, inserted an insulated wire, and potted up the hole with car Bondo. Added a 1/4 inch of gasoline, put a small plate of glass on top , and let it sit 5-10 minutes in the shade to let the gas evaporate. Wired in a hi-voltage sparker from an old grill, hit the sparker. Could clearly see the spark ~ 1/2 long from wire to inside surface of can, no flame.
Wire spark gap was at mid-height of can, I then lowered it to make spark gap close to surface of gas and sparked again, no flame. Took cover off and sparked again still no flame (gas vapor is heavier than air). Fanned some air into can with glass plate, sparked it, finally got flame.
Just to be thorough I moved spark gap to top of can, sparked it, no flame. Removed glass cover , sparked it , got flame.
So I think I will be safe playing with higher voltage to pump in tank, even if it does happen to spark inside tank. But for extra safty I'll add ~10 ft of romex wire for extra distance.
Hummm if 24 V doesn't work I'll try a small cap charged to a high voltage ~ 50VDC. Small cap can limit wire melting energy deposited in motor. Momentary high current might demagnetize permanent magnets in motor but it's junk anyways.
Last edited by len k; 07-19-2015 at 08:34:57 PM. Reason: added test with spark gap at top
  #1770
Old 07-19-2015, 05:34:40 PM
Jim McIntyre's Avatar
Originally Posted by len k View Post
...So I think I will be safe playing with higher voltage to pump in tank, even if it does happen to spark inside tank..
Yep. Gasoline has a high enough vapor pressure that the gas mixture over it won't burn.
Diesel is the opposite - low enough VP the mixture won't combust.
Any guess as to what happens when you mix them???
