this thread has 4880 replies and has been viewed 322454 times
Old 10-20-2015, 07:56:56 AM
Leon N. Leon N. is online now
Default Re: What have you done to your Onan generator today?
I have a suspicion that my Garretson is getting lazy and is responding erratically to the Onan suction pressure.
Old 10-20-2015, 12:02:30 PM
len k len k is offline
Could be oily inside from years of use. The oils that eventually deposit from nat gas use are sticky and tacky.
At least here they are.
Or just the lube grease has gotten old and dried up.
Old 10-20-2015, 12:24:14 PM
Reason I suspect it is the Garretson and not my JB is because the JB can be warmed up and just running perfectly at a constant no load speed and then for a few seconds it will cough, and hunt and vary speed then it will settle down for a while and then maybe a few minutes later go through another tirade. I suspose then govenor sensitivity is a tad to sensitive. However, the JB does meet the 2 second recovery requirement from NL to FL and the droop is only about 2 HZ.
Old 10-20-2015, 12:27:35 PM
As a test you could try marking the gov adjustments and reducing the sensitivity to see if that stops the occasional tirade.
I assume this cough still happens after you replaced your spark coil condensor.
Old 10-20-2015, 02:31:02 PM
Len K, Yes.
Old 10-20-2015, 06:52:12 PM
Jim McIntyre's Avatar
Hmm. I don't see how measuring the Garretson output pressure will resolve this. Even if it does vary, there'd be no easy to prove whether that was the cause or an effect of the throttle position changing.
If I was worried about it, I'd just replace the old Garretson. They have a rubber diaphragm that can't be expected to last forever.
Old 10-20-2015, 06:54:49 PM
Don't they have rebuild kits for the reg? There's not much inside them, would guess you just want to replace diaphragm, maybe seal on valve seat. and lube pivot.
Maybe put Permatex 2 (for car engines) on the OD of diaphragm to seal to case, that stuff seals just about everything.
Old 10-20-2015, 07:21:01 PM
Jack Hottel Jack Hottel is offline
Don't forget that at the output of the demand regulator is vacuum. With a manometer connected, a hiccup in the regulator may empty the manometer into the carb.
Jack Hottel
Old 10-20-2015, 07:27:55 PM
Somebody might sell them, but not Garretson. I have to think it's a liability thing. The latest KN regulators I bought had the pressure adjust screw lock-tite'd to make it REALLY hard to adjust...
Not saying it's good or bad, just the way it is..
New KN's are around $50, and come with a primer button.
I buy 'em here:
http://www.carbturbo.com/
Old 10-20-2015, 07:50:28 PM
All good comments. You know, the condition I am observing can be artificially created by miss adjusting the carb main metering jet. That is why I suspect the KN2. Just remembered, I do recall purchasing a KN2 rebuild kit. It is out in the shed somewhere. But I don't relish the idea of taking down the KN2. I think I will try to desensitize the govenor first. That is the easy way out. All I need is a screw driver and what a 5/8 box wrench. But then I will have to run a load test again to make sure the frequency stays within spec. More later.
