30HP Bessemer FC
this thread has 9 replies and has been viewed 1111 times
Old 04-08-2019, 01:59:12 PM
con-rad con-rad is offline
Default 30HP Bessemer FC
Hey all,
After making a deal last october, I finally got a truck and trailer organized to haul this engine! It was a nightmare to haul, including blown trailer tires, an F550 dying on the road, and lug studs shearing off the trailer axle. After many hours and dollars it came to rest at it's new home at the Zagray Farm Museum in CT. It last ran about 10 years ago and i was told it had a stuck valve. As you can see, the real issue is a broken valve keeper/guide. Not sure how I will go about repairing it yet, but i'm open to suggestions!
ID:	332345   Click image for larger version
ID:	332346   Click image for larger version
ID:	332347   Click image for larger version
Old 04-08-2019, 04:21:13 PM
KeithW's Avatar
KeithW KeithW is offline
Default Re: 30HP Bessemer FC
It looks like someone tried to repair it in the past by welding it. My thoughts would be to fabricate a new one unless a good used or new can be found.
Old 04-08-2019, 10:22:29 PM
How about drilling thru the flat of the "bowl" and drilling/tapping the center guide then bolting the 2 together?
Parts for a Bessemer FC are like hen's teeth but even more so for the 30! Bill Klein
Old 04-09-2019, 06:55:19 AM
Nice engine Conrad !! You have quite a collection going there.
Old 04-09-2019, 09:12:43 PM
WP Klein, that sounds like an interesting idea! I was going to cut off the nickel weld and try brazing it, but I am more confident in my drilling and tapping abilities! Maybe I will braze it first to stick it together and drill and tap later. I will have to look closely at it, there isn't much meat to drill into due to the angles of the crack and the sloped sides of the center hub. Worst case scenario, it's not the hardest thing to machine brand new.
Connor
Old 04-11-2019, 06:24:36 PM
Cleaned up the gas mixer and gas cock today. The handle to the gas cock was steel and I wanted it pretty, so i wire wheeled it shiny, and heated it with a torch to a couple hundred degrees. Then i bushed it with a brass brush. The heat melted and transferred a small amount of brass from the brush bristles to the steel handle, giving it a brass look. The mixer valve was all stuck and gooey inside, so I brushed and honed it out, and hosed out all the rust and goo with solvent.
I have heated the broken valve keeper twice to drive out oil. I will cut off the nickel weld, braze it together, and then drill about 6 holes, and tap them per Klein's suggestion to screw it all together.
I also made a air choke plate for the intake.
https://www.youtube.com/watch?v=OTr_...5sp1ark0h00410
connor
ID:	332507   Click image for larger version
ID:	332508   Click image for larger version
The Following 2 Users Say Thank You to con-rad For This Post:
Old 04-15-2019, 09:14:33 PM
I enjoyed the video. Thank you. Bill Klein
Old 04-16-2019, 08:14:52 AM
Interesting video Conrad. Was that taken at your house, or at the Museum?
Old 04-16-2019, 05:35:22 PM
The unloading was at the museum. I don't have equipment big enough at home to unload it!
Brazed and pinned the upper valve guide/keeper. Only issue was that i lost concentricity between the OD and the threaded hole for the valve stem. I'm going to chuck the part in a lathe and turn down the high spots this weekend, and the repair will be done!
connor
Old 04-24-2019, 10:12:25 PM
Fixed the valve guide!
https://www.youtube.com/watch?v=uZ61yPnijjs
Put out a quote request for some new copper washer gaskets for the valve chest and air start intake valve. Soon it will be coming together! After some plumbing it will be ready to go.
Connor
30hp St Mary running J.B. Castagnos Antique Gas Engine Discussion 0 10-20-2015 08:34:22 PM
30hp Olin JWithers Antique Gas Engine Discussion 5 09-27-2013 10:34:00 PM
30hp Headless Witte JWithers Antique Gas Engine Discussion 1 11-14-2012 09:44:09 AM
Superior 30hp C-Wade7 Oil Field Engines & Related Equipment 1 10-21-2008 10:29:19 AM
30hP Foos Craig A Antique Gas Engine Discussion 1 01-20-2005 10:39:48 PM
