Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
Jacking up a Forklift?
this thread has 70 replies and has been viewed 15209 times
Old 01-31-2013, 09:36:59 PM
topmach topmach is offline
Default Re: Jacking up a Forklift?
I am lucky mine is accessible from the side. A shop I worked in had the starter go out in the smaller CAT. We just used the big one to lift it up like a car hoist.
I would use several 2in blocks and start jacking one end then the other, lifting it 2in at a time. Make one block with smaller blocks on either end like wheel stops, and just keep raising and shimming them 2in at a time.
If you can get it started, make ramps out of blocking. Another option is to dig a pit.
Good luck and be careful,
Josh
The Following User Says Thank You to topmach For This Post:
Old 01-31-2013, 10:05:00 PM
len k len k is online now
Slopes......I would be VERY CONCERNED about slopes !!! You really want a level place to work on it !!! Slopes make whatever vehical your lifting want to roll off.
Even on my level driveway , if I jack front of car up high ( ~ 2 cement blocks) and lower car on the blocks, they want to roll backward. That is why I jack+cement block both ends of car when going high , to keep it level and stop the rolling. (IF I only jack one end not too high I also rotate the blocks ~25 deg on both sides , so any block rolling fights each other and they don't roll). I support the frame, not tires, it's more stable.
Wide Wood blocks would be better than cement, but my wood is only 6x6 , it wants to roll too much when I go high, my cement is wider. Could use railroad ties, but don't have any.
Cement is a brittle material so if you use it, slowly lower weight onto them, don't trust them to stop a falling vehical.
The car is a 1991 Chev Caprice ~4000+pounds, it's front heavy , engine in front., I don't know what a forklift weights.
---------- Post added at 08:53 PM ---------- Previous post was at 08:49 PM ----------
(when I say 2 cement blocks I mean long side laying down, so each block is only ~8 inch high)
---------- Post added at 09:05 PM ---------- Previous post was at 08:53 PM ----------
The rolling seem to not just be caused by gravity pulling the vehical downhill. Even on level pavement, When only one end of vehical is jacked up and lowered on a block, the frame hits on only one edge of block and vehical always seem to want to roll till frame sits flat on block. But then block rolls and one edge is off ground, just doesn't look safe.
The Following 3 Users Say Thank You to len k For This Post:
Old 01-31-2013, 10:13:02 PM
jgreen416 jgreen416 is offline
I agree with all of the posts that say avoid cement blocks. When I owned a lumbryard in Michigan, I had to have our C-60 Hyster off the ground on several occasions.Always use wood blocking and keep machine very close to level. It is helpful to have a winch or chain fall to pull the machine rearward onto slight ramp bocking under wheels to give you clearance for 20 ton bottle jack. The rest is just slow andeasy does it till blocked to proper height. Good luck.
JG
The Following User Says Thank You to jgreen416 For This Post:
Old 01-31-2013, 10:20:37 PM
Gary K's Avatar
Gary K Gary K is offline
Images: 394
jacking up a forklift - Google Search
http://www.google.com/search?sourcei...I7TSNP_enUS483
Gary K
The Following 2 Users Say Thank You to Gary K For This Post:
Old 01-31-2013, 10:29:44 PM
Canadian made Canadian made is offline
I work on forklifts all day. To go under one for a job like this we use hardwood ramps that gets the front about 8 inches off the ground plus whatever the original clearance would be. Any type of solid wood will work. Remember to chalk atleast one wheel and remove the key while you are under it.
The Following User Says Thank You to Canadian made For This Post:
Old 01-31-2013, 11:25:42 PM
Once had to change exhaust on a car away from home. Next door was a dumpster with tons of new scrap 2x12 wood . I made a ramp, I laid the peices down to form a strip , then next strip a little shorter , and so on.
Don't go too high, or it gets unstable/tippy. Before you get under it , give forklift a good shove and shake, to make sure it's not shakey/flimsy. Better it falls off ramp/blocks then, instead of later with you under it.
Just curious , what do these things weigh?
---------- Post added at 10:25 PM ---------- Previous post was at 10:22 PM ----------
Forgot to say......... When I was away from home , I once changed my oil by driving front wheels up onto curb. And laid on cardboard (thiner than a creeper)
Old 02-01-2013, 04:49:21 AM
Toesmack's Avatar
Toesmack Toesmack is offline
Images: 7
Finally got rid of the old Clark huh? Really thought you might plant it over in Ruth, NV next to the old blade in the park!
How big a fork we talkin' here? Weight on these is insane. My 6,000lb hyster weighs between 9 and 10,000 lbs. Also have a 5k TCM, weighs right at 8,000lb. Removing the counter weight will lighten the load, but sure is a full load by itself, and is unlikely to give you access to the starter. A running engine will allow you to use the mast tilt and progressive blocking to get it in the air. Can you bump start it?
What make and model is the newer machine?
The Following User Says Thank You to Toesmack For This Post:
Old 02-01-2013, 02:19:01 PM
Glenn Ayers Glenn Ayers is offline
Good point Otto & others about not using concrete blocks PERIOD ! I will use them around here some times ... just under a car wheel or small tractor ... but not a good idea under something as heavy as a forktruck. I merely was stating that IF/WHEN using a concrete block ... ALWAYS use it "eye up".
dalmatiangirl ... you said you have a loader ... is is big enough to tip the rear of the forktruck far enough to stand it on it's nose like someone else here has suggested ?
Just throwing out ideas ....
The Following 2 Users Say Thank You to Glenn Ayers For This Post:
Old 02-01-2013, 02:28:05 PM
Can ye put the machine in gear and pull start it and then drive it up on something wood to get it up a bit higher?
I wouldnt want to get under a forklift with anything under it but STEEL or wood.
I beams would work.Something STRONG.
A starter aint worth kicking the bucket over.
A friend of mine when he was young had a 39 Ford chained to a tree limb changing out the rear axle and the limb broke.He has had artifical legs for 60 years or so.Lucky to live thru it.
The Following 2 Users Say Thank You to uglyblue66 For This Post:
Old 02-01-2013, 02:46:32 PM
Well at those weights I would say NO to hollow cement blocks.
I get just a little nervous on my ~4000 # car even with 3 eye blocks, but I give it a good shake and felt comfortable with the result.
I figured a 16 foot tall cement wall would be 20 blocks at ~50# each , so bottom block would have 1000lbs on it plus maybe anothe 700 # of snow load (load bearing wall) for total of ~1700lbs. Which would be ~ in line with weight on each side of front of my car.
---------- Post added at 01:46 PM ---------- Previous post was at 01:41 PM ----------
(I assumed you had a little lift, that was lighter than a car. )
Old Towmotor Forklift Fred Prichard Lifting and Loading 14 07-09-2018 05:09:21 PM
Forklift Question Greg Shipley Lifting and Loading 19 10-15-2017 10:43:35 PM
CAT Forklift 501P Miehle48 Lifting and Loading 1 06-25-2012 10:10:02 PM
Forklift Not Included DaveTexas Antique Gas Engine Discussion 5 03-02-2011 12:37:22 PM
