Welding Shop
Lincoln Weldanpower 150
this thread has 19 replies and has been viewed 1006 times
Old 02-25-2018, 01:08:04 AM
cobbadog cobbadog is offline
Default Re: Lincoln Weldanpower 150
Glad you have your part. Let us know how you get on and if it works again for you.
Old 02-25-2018, 11:46:56 AM
jerkputter jerkputter is offline
Will do. It should be here this week.
Old 02-27-2018, 03:14:28 PM
Got the rectifier installed. It will generate power but I have to start by taking a 12 volt battery and jump it to positive side of brushes. The second I touch the wire to positive lead on brush it will start putting out power.
The flashing mag is weak.
To weak to get this thing started. My AC output is 1 volt, sometimes less than that. Not enough.
It is supposed to have 1.4 to 4 AC volts.
There were instructions on the weldingweb site before it went down on how to rewind the flashing mag and what wire to buy ?
I didn't write that down.
Anyone know how to do this. Tom
Old 02-27-2018, 08:35:34 PM
dkamp dkamp is offline
before going through that, make certain that the dc leads are connected in proper polarity, then start it up, connect a load and flash it, and then give it a good heavy load to grind on for a half hour, then shut it down, let it set for a few minutes, then try it again.
self excitation requires a little residual magnetism. when you blew the bridge, that pumped ac through the field, effectively degaussing it.
Rather than flashing, you could use my other non invasive trick... slap a big magnet on the outside of the exciter, move it around till the 75w lightbulb you plugged in starts to glow, and then plug in a 1500w milkhouse heater set to half power, and let it work. it'll rebuild that residual in a half hour our so. Safe and easy.
Old 02-27-2018, 11:37:26 PM
Thanks, I will give that a try and let you know. Good info . Thanks again. Tom
Old 02-28-2018, 08:16:22 AM
I am not sure I understand how to do this ?
The only magnets I have are the ones I remove from old computer hard drives. I work on computers as a side job and found the magnets in those larger desktop drives have very strong magnets.
Any pictures on how exactly to do this ?
You saying I don't need to flashing coil to make this thing kick off ?
I am not quite sure how to go about doing what you mentions ?
Old 02-28-2018, 06:58:18 PM
I do understand the first step you mentioned. I will try that tomorrow with my electric heater and see if it works.
The second method I am not 100 % sure on. Anyway I will report back how it goes.
Old 03-01-2018, 12:29:55 AM
Just take a stack of those computer magnets... stack them all together tight, so they're one massive fistful, start the generator, with an old-fashioned light bulb connected, and put that magnet against the generator frame. Move it slowly from one end to the other, and when you see a glow in the bulb, LEAVE the magnet where it is...
Old 03-01-2018, 07:23:45 PM
dkamp, your first tip worked like a dream. I flashed it with a 12 volt battery.
Plugged in my electric heater and let to run with heater on wide open for 30 minutes.
Turned it off and let it sit for 15 minutes.
Started it back up and I did not have to flash it this time.
I even welded with it for 10 minutes. THANKS so much. Never would have got it going if not for you. Its old like me but still works. Tom
The Following User Says Thank You to jerkputter For This Post:
Old 03-01-2018, 10:56:51 PM
What a great outcome. We are happy for you that your welder is back in action and ready for use.
Lincoln Weldanpower 130 Jim Geraci Welding Shop 0 10-12-2016 03:03:04 PM
lincoln WeldanPower 150 engine trouble robert d Kohler Generators 9 04-16-2015 09:10:05 AM
Lincoln weldanpower 225 Stonedan Magnetos, Ignition Coils and Spark Plugs 1 08-26-2013 04:32:03 PM
Lincoln /weldanpower 125 Stonedan Welding Shop 4 08-13-2013 04:25:00 PM
Lincoln weldanpower with B&S 16hp liston336 Welding Shop 3 03-23-2010 08:59:54 PM
