Mep-802a
this thread has 2 replies and has been viewed 515 times
Old 02-18-2018, 02:52:10 PM
z2003k z2003k is offline
Default Mep-802a
I have a chance to buy a 1997 mep802a. Are the older ones any better/worse than the newer ones?
Old 02-18-2018, 07:28:06 PM
dependable dependable is offline
Default Re: Mep-802a
Age is not as much a factor as condition the unit is currently in, some older machines may have just been rebuilt, some newer ones may have been in field for many hours.
The Following User Says Thank You to dependable For This Post:
Old 07-04-2018, 06:21:31 PM
bunkclimber bunkclimber is offline
i deal in these MEP units big and small,the Lister Petter/Onan engine in the small MEPs go about 10,000hrs before overhaul if treated right with regular oil changes and basic maintenance.Other things to look for are loose electrical connections,chafing and rotting rubber fuel return hoses,clogged fuel pre-filters at the fuel lift pump.Malfunctioning electricals are sometimes an issue due to vibration and shipping shock from handling.Radiators and water hoses have been good,not too many issues there.You can replace the thermostat with a lower 160 deg temp one.The Libby and Fermont units are both just as reliable as each other,no real big difference between the two in terms of reliability.If you can get one with less than 1000hrs on it if you have your choice.FWIW
MEP-802A rewired 12 wire panzerwillie Onan Generators 2 03-25-2017 09:11:12 PM
Mep 802a what do you think it is worth dave2500 Military MEP and Aircraft Gen-Sets 6 02-03-2015 09:32:39 PM
About picking up 3 MEP-802A gensets! pclausen Military MEP and Aircraft Gen-Sets 18 12-28-2014 04:31:31 PM
MEP-802a wireing question JR2980 Military MEP and Aircraft Gen-Sets 4 04-07-2014 08:05:29 AM
