Bosch HDH 1908 mag
this thread has 1 replies and has been viewed 245 times
Old 01-25-2019, 09:18:00 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Default Bosch HDH 1908 mag
Anybody know what this mag fits??
Serial number is right near the line between 1907 and 1908.
Appears to be for a 4 cylinder.
This one is missing one pair of magnets if anyone knows where I might find some.
Thanks
Jonathan
ID:	327100   Click image for larger version
ID:	327101   Click image for larger version
ID:	327102   Click image for larger version
The Following 2 Users Say Thank You to Sad Iron For This Post:
Old 02-01-2019, 11:07:37 PM
Wayne Timms Wayne Timms is offline
Default Re: Bosch HDH 1908 mag
Hi Jonathan,
I have one the same.
They were used on Dutch Spyker cars. If you haven't already, undo the small screw at the front of the magneto and carefully pull the top cover forward, you will see that it is not your 'normal' magneto inside. None of the windings turn.
High RPM would not be a problem for this magneto.
I see yours is marked 'HDH', mine is marked 'HDh'.
I am sure they would have been used on other things. I haven't seen many of them in my travels.
Regards,
Wayne
1908 Maxwell Modeltmedic Antique Autos and Trucks 5 12-27-2017 09:54:28 AM
American Bosch, Bosch magneto ZR4 vs DU4 Interchangable? glenshep Magnetos, Ignition Coils and Spark Plugs 4 03-25-2014 02:19:07 AM
R.E. Olds until 1908 Denis Rouleau Antique Gas Engine Discussion 0 03-03-2014 12:34:32 PM
1908 25 HP 1908 Fairbanks Morse - Where is it now? Larry Evans Antique Gas Engine Discussion 1 11-14-2011 08:46:22 AM
1908 Gas Review Sta-Rite Ads. Denis Rouleau Antique Gas Engine Discussion 0 12-05-2008 04:51:46 PM
