Forklift Ignition Ducellier Distributor
this thread has 16 replies and has been viewed 984 times
Old 06-27-2018, 09:11:15 AM
Greg Shipley Greg Shipley is offline
Default Re: Forklift Ignition Ducellier Distributor
thanks for the ideas guys. I will get the distributor apart and look it over so I can figure out what i have for room and go from there, I will keep the thread updated as I progress. thanks again for the ideas.
---------- Post added at 08:11:15 AM ---------- Previous post was at 07:51:30 AM ----------
on the back to points topic, isn't the lobes on the shaft for the points machined into the shaft? or is it a ring as well?
Old 06-27-2018, 05:09:24 PM
debe debe is offline
They are usualy pressed on to the shaft.
Old 06-27-2018, 09:31:10 PM
s100 s100 is offline
I was thinking to remove your distributor and use it to find one that is as close as possible to yours in size and configuration, then do whatever you have to do to make it fit your engine. Depending on what you come up with this could involve quite a bit of work but to all intents and purposes this is a lifetime fix, especially if you sock away a couple of sets of points and caps/ rotors.
Old 06-28-2018, 11:20:41 AM
Mike Hole Mike Hole is online now
Take a look at pertronix ignition. They make kits to do conversions.
Their website www.pertronix.com
I've installed several of their systems in the last 10 years or so and had no troubles.
Mike
Old 07-09-2018, 09:22:13 PM
Marius Titulescu Marius Titulescu is offline
Thanks for sharing, Mike. I've also heard quite a lot of good things about them.
________________________
Marius
GCS Forklifts
Old 07-10-2018, 04:07:20 PM
mmcdonald mmcdonald is offline
Banner Sponsor
Sorry I haven't put my 2 cents in since earlier. I spent a few minutes looking at this. I think one of the "DU/LE/141/142" type ignitor kits would work in your distributor but it would take a little examination to figure out which one. The main issue with installing an ignitor in a non listed application is finding a magnet sleeve to fit. There is typically room to mount the pickup even if it's not super easy. Once you have found a kit with the right magnet sleeve and figured where to mount the pickup then replacing it in the future will be relatively easy(assuming it is still in production the next time you need one). Aside from that I found this
http://www.123ignition.nl/product.phtml?id=64
Although not optimal in my eyes this is one dealer in US
http://123ignitionusa.com/peugeot/
We are a Pertronix WD but I have no affiliation with the other company and only post trying to be helpful. Good luck.
info@mcdonaldcarb.com
Old 01-26-2019, 02:18:20 PM
Electricben Electricben is offline
Hi Guys, do have over 30 yrs of experience with the French Ducellier, SEV, RB and Paris Rhone ignition distributors.
Still have an interesting stock of new parts.
I do live in the Netherlands, Europe, but can send parts all over the world by post.
Send pics as a pm to me and i will contact you!
Electricben
Jacking up a Forklift? dalmatiangirl61 Lifting and Loading 70 12-08-2015 08:16:14 AM
Wisconsin VH4 Ignition Wires, Coil & Distributor Cap Hugheski Wisconsin Engines 4 11-14-2014 11:13:01 PM
Forklift troubles. :( Greg Shipley Lifting and Loading 22 08-02-2014 11:16:39 AM
CAT Forklift 501P Miehle48 Lifting and Loading 1 06-25-2012 10:10:02 PM
Ducellier 12 V Coil Specs turfcat idol Garden Tractors / Mowers / Scooters 5 09-06-2011 11:48:03 AM
