Oil Field Engines
US Oilwell Witte Info?
this thread has 15 replies and has been viewed 1747 times
Old 11-21-2017, 08:12:50 PM
OilfieldTrash OilfieldTrash is offline
Default Re: US Oilwell Witte info?
I still haven't found a serial or any clear way to ID it. Getting ready to dose the cylinder with tranny fluid and diesel and see if she will free up. The flywheel is pinched on with a bolt, the clutch side has a clamped on flange that the Rockford style flywheel bolts to...which is broke. I'll post some detailed pictures tomorrow if possible.
---------- Post added at 07:12:50 PM ---------- Previous post was at 07:07:37 PM ----------
After looking at the catalog, I think...key word is think...it is an E20RC.
Old 11-21-2017, 09:31:08 PM
Reed Engine's Avatar
Question Re: US Oilwell Witte info?
Loosen the conn rod bolts about half way and that will give you some bump to get the piston moving. Use the flywheel.
Old 11-24-2017, 02:39:08 PM
Filled cylinder with alittile used oil and some atf. Gonna let that stew for a bit, then loosen the rod bolts a bit and see if she frees up any.
Old 11-25-2017, 04:03:45 PM
Victory!Click image for larger version
The Following 2 Users Say Thank You to OilfieldTrash For This Post:
Old 08-04-2018, 09:51:24 PM
Billmercer Billmercer is offline
Greetings -
We are missing the Simplex Pumping Jack and the connecting arm piece that straddles the well (see attached drawing).
Do you know where we could obtain one?
I am donating my Dad's Oil Well to be used as a display at our Restored Village: South Side Historical Village, near Pittsburgh, PA.
Website: https://sshva.wordpress.com/
South Side Historical Village Association | "The Home of ...
sshva.wordpress.com
The South Side Historical Village was established in 1995, and is located at the Hookstown Fairgrounds in Hookstown, Pennsylvania. Our Mission: To Collect, Preserve & Interpret Early American Life.
God Bless
Bill & Ruth Mercer
724-312-4048
billmercer39@hotmail.com
Old 08-05-2018, 10:31:29 AM
David A. David A. is offline
reed worked with me on my crc witte, I about ran him crazy with all the questions, but he survived and I thank him for it all, he is knowledgable and helpful, THANKS again ED
The Following User Says Thank You to David A. For This Post:
"OILWELL" 2 cycle info wanted TheFairbanksKid Oil Field Engines & Related Equipment 14 03-16-2014 08:17:13 PM
Will a USS Oilwell 98 RC run on propane? Kirk T Oil Field Engines & Related Equipment 8 12-26-2012 10:15:02 PM
Witte B-12 oilwell gas tank RHudson Oil Field Engines & Related Equipment 4 07-29-2007 07:32:02 PM
Witte oilwell engine info RHudson Antique Gas Engine Discussion 3 07-18-2006 11:17:09 PM
Oilwell Jody S. Steam Stationary Engines, Traction Engines, Steam Boats 4 12-12-2005 01:05:07 AM
