Oil Field Engines
Sleeving FM 118
this thread has 12 replies and has been viewed 1221 times
Old 02-28-2018, 04:57:42 PM
Reed Engine's Avatar
Default Sleeving FM 118
Did one today, the first in a while. This one still makes #2112. The Rotler boring bar is such a good machine, still runs true after 2000 jobs. Glad to see things picking up out here again.
The Following 2 Users Say Thank You to Reed Engine For This Post:
Old 02-28-2018, 06:29:36 PM
Default Re: Sleeving FM 118
Ripping and pressing in the new. The ram is from the front of a road grader used to angle the blade. Here it’s used to pull the sleeve into the block.
ID:	304298   Click image for larger version
ID:	304299   Click image for larger version
Old 02-28-2018, 09:03:27 PM
Mike Cummins Mike Cummins is offline
What model is your Rottler? Looks like a big one.
Old 02-28-2018, 10:59:50 PM
Gary Reif Gary Reif is offline
Man that brings back memories. I worked in a shop about 20 years ago where we sleeved a lot of these engines, 118s, 208s, 346s, and 503s. We also sleeved 6 1/2, 7 1/4, 7 1/2, and 8 1/2 Ajax cylinders. We used a 999 Van Norman boring bar for those.
Old 02-28-2018, 11:54:58 PM
I’m not there to look at the model but it was the largest portable they offered. Was a custom order too, extra long column.
I’ve got 2 Van Normans too. Never used them.
---------- Post added at 09:54:58 PM ---------- Previous post was at 09:53:33 PM ----------
Yes, I’ve done Ajax too. I finally got to where I could mill the ports where they lined up 100%. Then that went away all together.
Old 03-01-2018, 12:45:58 AM
Yes the 999 had a taller column. The 8 1/2 Ajax was 22 inches long. Lots of fun cutting the ports in the sleeve to match when installed.
Old 03-11-2018, 11:23:06 PM
Allan Wright Allan Wright is offline
Mr. Reed, what is the ripping for? Are you removing an old sleeve?
Old 03-15-2018, 08:10:21 PM
David A. David A. is offline
I have a 10 3/4 bore 18 1/2 length cyl, 2 cycle, BRadford special, that is cracked close to exhaust port, tryied to have it stitch welded( pins), and cyl too thin, so what kind of options do i have to get her going again? any help is appreciated
Old 03-15-2018, 09:57:45 PM
Card Sponsor
Where do you get big sleeves say between 8 -12" ?I have been getting cast iron tube from M&N in Texas and making my own. . very pricey though, Thanks ,Rob
Old 03-15-2018, 11:00:31 PM
8” OD? Is the same as a 503 FM. I have them in stock 12” I don’t know. 8” is as big as I do.
Sleeving Pistons? Reed Engine Antique Gas Engine Discussion 18 02-21-2018 04:04:49 PM
Bore sleeving? Jon Mrozinski Antique Gas Engine Discussion 2 07-06-2012 11:09:50 PM
sleeving pulleys and such randyt Machine Shop and Tool Talk 7 12-30-2011 06:56:27 PM
Sleeving my Titan J.B. Castagnos Antique Gas Engine Discussion 9 10-16-2009 10:55:00 PM
Re-sleeving IHC 'M' David L. Showerman Antique Engine Archives 10 12-10-1999 01:51:15 AM
