Axle Shortening
this thread has 14 replies and has been viewed 1297 times
Old 08-08-2018, 04:52:58 PM
kwfiggatt kwfiggatt is offline
Default Re: Axle Shortening
Yep - max torsional stress is in the outer portion of the shaft. Torsional stress at the center is zero..
The Following User Says Thank You to kwfiggatt For This Post:
Old 08-08-2018, 05:52:16 PM
Charley K Charley K is offline
Hi, Back in the day, I narrowed several 9" ford rears. With 31 spline axels, you could cut the axel to length and re spline. The diameter was the same all the way to the flange. These held up well on the street hot rods. I have seen them twisted in the splines after many trips down the drag strip. They were not heat treated but did pretty well. The dana and 12 bolt rears took custom axels which were purchased from Moser. Good job, probably will work if they aren't abused. CK
The Following 2 Users Say Thank You to Charley K For This Post:
Old 08-08-2018, 06:04:01 PM
We raced a 55 Chevy in high school, used a 57 Pontiac rear end. We painted a stripe on the axle, would change them when it twisted 180 degrees. Most of the twisting occurred in the first foot from the spline.
Old 08-08-2018, 08:41:28 PM
JB made a point. I used to run 9" 28 spline axles behind a Lincoln 430 in a Ford. Man that thing made torque! I also painted a line on the axles out of curiosity and when they'd pop they often had three to five revolutions of the line. That old 430 also shredded spider gears and back then a new bone yard carrier was only $15. It also ate 3600 pound Scheifer pressure plates. It wasn't that fast but up to 90 it would out grunt almost everything.
I ran into a guy that had a bunch of NASCAR heads, manifolds etc, that I bought for a pittance. That stuff really woke it up.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
Old 08-08-2018, 09:09:53 PM
Reading about drilled axles, .875" hole weakens them 20 percent, guessing the axles are 1.25"- 1.50" diameter.
what is this axle for? B.L. Rodenkirch Antique Gas Engine Discussion 3 06-25-2017 07:07:47 PM
Odd WW1 wheel & axle Firewoodguy Antique Gas Engine Discussion 3 07-26-2012 01:30:51 PM
Axle Nut for MM GTA Molinegb Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-21-2009 07:59:58 AM
What Axle Is This ? Roland Finkenbinder Antique Gas Engine Discussion 0 01-30-2005 01:05:36 PM
Axle done eric M Antique Engine Archives 6 01-21-2004 12:38:40 AM
