Farmall Super H with IH three disk semi mount plow
this thread has 7 replies and has been viewed 3377 times
Old 01-21-2012, 03:40:53 PM
Pat Bayer Pat Bayer is offline
Default Farmall Super H with IH three disk semi mount plow
Hello, I'm needing some help attaching this IH three disc plow to the Super H Farmall. I was wondering if anybody has any pictures of one of these plows mounted on a tractor
ID:	126562   Click image for larger version
ID:	126563   Click image for larger version
ID:	126564   Click image for larger version
Old 01-21-2012, 06:31:06 PM
Default Re: Farmall Super H with IH three disk semi mount plow
Would anyone know what number this plow is, then maybe I could get a manual.
Old 01-21-2012, 07:47:40 PM
A photo or 3 which concentrate on the actual plow hitch would be real helpful.......
Old 01-21-2012, 09:18:27 PM
Tom Railsback Tom Railsback is offline
Call me at (406) 454-8758; I can put you in touch with someone who has one mounted on a wide front tractor and who has pictures of the steering setup for a tricycle front.
Tom Railsback
Old 01-21-2012, 09:48:06 PM
FarmSC's Avatar
FarmSC FarmSC is offline
HM150 I will look for pictures of mine. You seem to be missing a very important part that swings down from just under the pedals that the front of the plow hitch hooks to.
Kevin
Kevin Harbin
Seneca, SC
www.snowcreekmills.com
Old 01-21-2012, 10:01:04 PM
FarmSC's Avatar
Default pics of Farmall Super H with IH three disk semi mount plow
Heres a couple I found on the computer. I have a manual for it, but it is not scanned. I might try to work on that. By the way, the HM150 was designed for the H or the M Farmall. According to the book, if using on an H, you drop the third disk and only run with 2. My '49 H will pull all 3, but only in 1st gear in our good red clay.
Kevin
ID:	126596   Click image for larger version
Kevin Harbin
Seneca, SC
The Following 2 Users Say Thank You to FarmSC For This Post:
Old 01-21-2012, 10:20:45 PM
Thanks, looks like I'm missing the piece that mounts behind the seat also. Maybe and I can build the pieces
Old 02-28-2017, 04:13:58 PM
harriswb3 harriswb3 is offline
Was wondering if you ever got all your pieces? I just bought one of these plows myself and I have most of the pieces.
I'm missing the "Z Bars" that go up under the belly pump. I also do not have cyclinders and sleeves. The only other key item missing is the bracket that mounts to the steering.
I've got some work to do to get it in operational order, but will be looking for those pieces.
Farmall Cub - mounting a mid mount mower (Woods) Ihorse Antique Farm Tractors 9 05-07-2011 12:44:29 PM
Farmall Super A-1 Lloyd J. Antique Farm Tractors 1 04-04-2011 05:14:35 PM
Farmall A plow mount Travis Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 02-25-2010 02:41:08 PM
Farmall Super A or A1?? Mart Antique Farm Tractors 5 08-27-2008 08:54:06 AM
Farmall super M Craig A Antique Farm Tractors 0 02-24-2005 12:42:55 AM
