Onan 7.5JB-3CR - Panel Door
this thread has 11 replies and has been viewed 1772 times
Old 07-10-2014, 05:42:27 PM
nyetman nyetman is offline
Question Onan 7.5JB-3CR - Panel Door
Hi Everyone. This is my first post to this amazing set of forums. I bought a property a while ago that has a non-working Onan 7.5JB-3CR (Spec AD) that I would like to get back up and running. (Especially following the 4 day power outage we just went through.) After finding the Parts Manual and with a little help from a neighbor who is quite a hand when it comes to engines we figured out that it was missing the following:
  • Ignition Coil - Part #166-0346
  • Spark Plug Cables
  • Panel Door - Part #134-1039
The generator has been at least 8 years (maybe 10) since it was running last. So he figured it would be best to replace the Point Set (Part #160-0002). And I'll probably go ahead and order the capacitor/condenser (Part #312-0116) at the same time.
I've decided to try this out instead of buying the ignition coil: http://www.smokstak.com/forum/showth...29944&p=154159 (Thanks Elden!) Just waiting on the resistor from my local NAPA.
Re the panel door, my buddy thought we could come up with something instead of spending the $200+ (when you include shipping) for that part too. Would someone be kind enough to post some detailed photos of the panel (open and shut, preferably with a measuring tape) so I can see the door details and dimensions?
Cheers,
Neil
Old 07-10-2014, 08:53:29 PM
Default Re: Onan 7.5JB-3CR - Panel Door
Welcome to the STAK : the best source of ONAN info anywhere.
If after testing , the coil is bad, Kirk engines sells a twin tower coil for onan & Kohler engines along with a point saver ignition.
Stock Onan coils very seldom go bad, but it is possible.
I always start with cleaning the points, checking gap and making sure the wire to them from the coil is not shorted to ground where it goes through the points box.
http://www.kirkengines.com/index.php...IgnitionSystem
Is this a housed JB set?
Not sure what the door is if not.
Your JB is a later model unit being an AD spec. Give us the serial number and we can date it for you & get the factory build sheet for it.
your unit is a 120/240 volt single phase 4 wire re connectible YD gen end . You can download the YD manual from the Stickies at the top of the onan forum.
If you would like the rest of the JB parts , service & operating manuals , get us an e-mail that will take large PDF files and we will hook you up.
The Following User Says Thank You to Ed Sparks For This Post:
Old 07-10-2014, 10:35:35 PM
where did u get a 200 price for a door? is this the door that covers the carb? or some other door? im sure some of us will have the parts u need..
Old 07-11-2014, 01:47:05 PM
Thanks Ed and yellowlister for your replies.
Re the Ignition Coil, I can't test the thing. It's actually missing! Apparently the previous owner had a local company come take it to test it and for whatever reason they never brought it back. Same goes for the spark plug cables and door (all missing.) I wish I had known about the Kirk Engines coil. (Thanks for that Ed.) I would have went for that instead of getting the 2 larger 6v coils and now having to try and make them fit. I should have made my first post to the STAK a little earlier I guess.
And after I made my first post I realised I never explained very well what door it was I was after. It's the one with the "Powerhouse" and "Danger" stickers that covers the carb (like you said yellowlister.) Note: It' NOT the door that << Door ?? is pointing too. I highjacked the image courtesy Old Style's post here.
Full model number is 7.5JB-3CR/6153AD and serial number is D830657527. The factory build sheet would be great. I think I got all the other manuals (967-0223 and 967-0754, plus the YD manual). If there is anything else you think would be great I'd be happy to get them. I'll PM you my email address Ed. Thanks.
Old 07-11-2014, 03:50:19 PM
GHanners GHanners is offline
try srsales or sears for parts lot less than cummins onan
edit
quick search shows the door p/n 134-1039 for 112$ from sears
http://www.searspartsdirect.com/part...rst=0&shdPart=
Ph# for srsales
PHONE: 262-522-6644
FAX: 262-522-7077
The Following User Says Thank You to GHanners For This Post:
Old 07-11-2014, 04:56:50 PM
here is the build sheet
The Following 3 Users Say Thank You to GHanners For This Post:
Old 07-11-2014, 07:13:26 PM
What you have:
7.5JB-3CR/6153AD 7.5 kw 2 cyl cast iron JB aircooled engine with a
3C code[120/240 volt reconnectible 4 wire gen end]
The AD tells you it's a YD gen end
Build date of:
D [April]
83 [1983]
0 built in Fridley Mn.
657527= unit serial number
I'll send you a couple other JB manuals later tonight.
Ed
Last edited by Ed Sparks; 07-11-2014 at 07:38:23 PM. Reason: corrected fat finger typing
Old 07-11-2014, 07:24:30 PM
JerryLee JerryLee is offline
Originally Posted by Ed Sparks View Post
What you have:
Build date of:
D [April]
83 [1982]
Ed
Ed, Wouldn't that be a 1983 build date?
Old 07-11-2014, 07:37:10 PM
Yep::: fat fingers on my keyboard.
Old 07-14-2014, 11:54:33 AM
Thanks GHanners. Where do you go about getting the build sheet?
Have just contacted srsales. searspartsdirect.com won't ship to Canada. :-( Will try calling Sears Canada Parts instead.
And I've also just registered with Cummins QuickServe Online.
What you have: .....
Thanks for the extra info Ed. Every little is helping.
WANTED - Onan 30EK-15R Weather Housing Side Door Panel - Spec F DonBadajoz Onan Generators 2 05-06-2014 11:09:45 AM
WANTED - Onan 30EK Weather Housing Side Door Panel - Spec F DonBadajoz Onan Generators 0 09-16-2013 02:56:07 PM
Onan 5.0cck/3R Panel squidtrap Onan Generators 2 08-12-2013 02:30:00 PM
Onan Generator and Panel pennytugboat Onan Generators 17 04-13-2011 08:42:07 AM
Onan Control Panel danny carter Onan Generators 4 07-17-2009 09:21:17 PM
