Onan MDJE Namplate Location
this thread has 5 replies and has been viewed 427 times
Old 03-03-2017, 01:14:45 PM
waterman46 waterman46 is offline
Default Onan MDJE Namplate Location
Any body know where is the location of the nameplate on my Onan MDJE generator (manufactured about 1982)? Looked all over the thing and can't find it. Need to find the nameplate because that information seems to be the only way the Onan-Cummins dealer can find information on the injection pump. KiKi injection pump has developed leak where the outlet valves thread into the pump body.
Old 03-03-2017, 01:57:07 PM
Billy J Shafer's Avatar
Default Re: Onan MDJE Namplate Location
Most of the time. It is on the belt guard up front. Look for six numbers stamped into the block. That is the serial number. Should be around the oil fill tube.
Old 03-03-2017, 03:40:50 PM
BigBlockChev's Avatar
BigBlockChev BigBlockChev is offline
I have 8 or so MDJE/B s and half of them don't have a nameplate anywhere on them. Cheers Dan
It's always something simple.
One test is worth a thousand guesses.
If some is good and more is better then too much is just enough
Old 03-09-2017, 07:41:34 PM
Hey Dan, I would pay a good price for a Kiki injection pump on one of those if you want to part out.
Old 03-09-2017, 07:57:35 PM
Surprised no one said not to go to a onan Cummins dealer..
You should try a injection shop. I have a stuck Kiki pump that is not damaged, we'll that I know of.. just needs to be unstuck.. it came from a dje
Old 03-17-2017, 12:03:15 PM
Found two holes in the flywheel housing where nameplate was supposed to be. Wonder why Onan made this attachment so fragile.
Injector pump won't have to be replaced. I found leak was caused by broken copper seal washer behind delivery valve.
Thanks to all who replied and to the forum!
onan 7.5 MDJE needs help blaise805 Onan Generators 35 04-20-2014 05:07:10 AM
Onan MDJE 6-7.5KW Help Mainshiptom Onan Generators 4 04-19-2010 05:32:50 PM
Onan 7.5 MDJE - 3CR Help LarryGlover Onan Generators 11 07-19-2007 04:38:12 PM
Waterloo namplate location dohouser Antique Gas Engine Discussion 8 10-12-2006 08:30:16 AM
Onan MDJE 6-7.5KW Help Mainshiptom Onan Generators 0 09-28-2005 05:48:23 AM
