Onan 4.0BFA need some sheetmetal
this thread has 4 replies and has been viewed 1446 times
Old 04-22-2009, 06:11:35 PM
Don Smith
Default Onan 4.0BFA need some sheetmetal
I just obtained an Onan 4.0BFA-1R/1600 that has suffered a bit of damage during a RV accident. While I was able to save the flywheel and most of the sheetmetal, the flywheel baffle cover and cylinder cover for the right side. (Oil filter side) Also the rear cover for the generator end. The damage is too extensive to try to save with my limited ability. Would like to find a replacement, for each, from someone's boneyard, that I might purchase. Thanks Don
Old 05-21-2009, 01:38:57 PM
Don Smith
Default Re: Onan 4.0BFA need some sheetmetal
I am still in need of this sheetmetal or someone who is good at bodyworking on my old bent up pieces. The two worst pieces are the flywheel cover and the cylinder head cover that has the model tag mounted. Gladly pay for help with this process Thanks Don
Old 05-21-2009, 08:43:56 PM
Don
Post a few photos of the sheet metal that needs fixing. I may be able to help.
Jim
Old 05-22-2009, 04:48:14 PM
Don Smith
Hi Jim Here are a couple of pictures of the flywheel cover. This is the piece that suffered the worst damage. The cylinder cover picture was over exposed and needs to be taken again. Will forward it shortly. Thanks Don
ID:	54950   Click image for larger version
ID:	54951   Click image for larger version
ID:	54952   Click image for larger version
Old 05-29-2009, 04:53:50 PM
Don Smith
Hi Jim. Have you had a chance to check out the pictures on the sheet metal? Is it something you could help me with? Thanks Don
Differences: 4.0BFA vs 6.5NH ASavage Onan Generators 7 11-28-2006 08:01:45 AM
Onan 4.0BFA armature stuck during disassembly Sage Trepasso Onan Generators 5 12-23-2005 09:04:36 PM
Onan 4.0BFA Won't crank Sage Trepasso Onan Generators 16 09-08-2005 10:03:22 PM
John Deere sheetmetal man? Jim Stigerwalt Antique Farm Tractors 5 02-27-2005 02:26:18 PM
Onan CCK Sheetmetal Ted C Onan Generators 0 09-13-2004 09:06:27 PM
