JD 45 combine transmissions
this thread has 5 replies and has been viewed 2648 times
Old 02-10-2012, 02:14:06 PM
Casemaker Casemaker is offline
Default JD 45 combine transmissions
Does anyone know of a place to get JD45 combine transmissions ? If I could pick several up it might be worth my while to make a trip.
Old 02-10-2012, 02:54:46 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Default Re: JD 45 combine transmissions
I just returned from a trip to Tenn. and saw one being hauled down the Interstate for scrap. Their all pretty much gone, just have to keep checking out old equipment dealers and farm back lots for the odd survivor. Believe it or not I also found a 110 Case boiler set up for steaming tobacco, looked to be in decent shape! F.J.W.
Old 02-10-2012, 03:02:01 PM
kelden kelden is offline
I just made a fork lift with one,eazy conversion,works great.
Old 02-13-2012, 06:12:20 PM
does anyone know of any salvage yards that might have some jd 45 combines these are the early 2 row models...some other models might have the same transmissions as well. Thanks
Old 02-13-2012, 08:17:45 PM
Fred Van Hook's Avatar
There is a equipment junkyard close to Alamo Indiana that might have what you need.. It is Edwards Equipment. If you want more info PM me and I can give you their PH#.
---------- Post added at 07:17 PM ---------- Previous post was at 06:27 PM ----------
I found their website, Here it is:
Edwards Equipment
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following User Says Thank You to Fred Van Hook For This Post:
Old 02-14-2012, 03:20:09 AM
Jim Anderson's Avatar
Jim Anderson Jim Anderson is offline
If you don't find any down in your area, we have two junk 45's up here in west central Wisconsin.
The Following User Says Thank You to Jim Anderson For This Post:
Fairbanks Morse planetary reversing transmissions model number A625A dw1973 Small Air Cooled Gasoline Engines 0 02-04-2011 01:02:45 PM
Fairbanks Morse planetary reversing transmissions model number A625A dw1973 Garden Tractors and Mowers 1 02-04-2011 01:00:12 PM
Fluids For Flushing Transmissions flatfenders-n-flatheads Antique Farm Tractors 8 12-07-2010 04:11:50 PM
Interesting marine transmissions for martin and greg a mschreiber Small Air Cooled Gasoline Engines 2 10-22-2010 12:41:16 PM
variable ratio belt transmissions GuyW Garden Tractors and Mowers 1 11-03-2005 06:11:49 AM
