JD 46 A where can I find main bearings?
this thread has 5 replies and has been viewed 1508 times
Old 12-07-2012, 08:24:33 AM
SlantdashA SlantdashA is offline
Default JD 46 A where can I find main bearings?
Is the John Deere dealer the only place I can find some main bearings? How much are they? Is there someone out there making their own at a more reasonable price? Happy Holidays! Thanks.
Old 12-07-2012, 12:46:16 PM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
Default Re: JD 46 A where can I find main bearings?
What's your s/n? I looked them up on JD parts one set was 140. the other was 180. Did an internet search after market was a little cheaper. Is the crank's in good shape and there's still adjustment left (shims) I'd leave it be. You'll never wear it out unless you want to plow or pull with it.
The Following User Says Thank You to John in Maryland For This Post:
Old 12-07-2012, 01:03:06 PM
The s/n tag is gone, I know it is a 46. Where are you finding the after markets? The original crank was ran dry because the oil filter clogged and one of the oil lines broke. The bearings wore down to the brass. I found a good replacement crank.
Old 12-07-2012, 01:08:30 PM
You can have your old shells repoured as well. You should check the price on that as well.
The Following User Says Thank You to John Schwiebert For This Post:
Old 12-07-2012, 09:32:18 PM
My connecting rods are the Babbitt type and need to be repoured......anyone know anybody that can do it? Typically what does repouring cost?
Old 12-07-2012, 11:59:15 PM
How about that? >>> http://www.oldjdforyou.com/mm5/merch...tegory_Code=73
If you know your tractor to be a 1946 model the starting serial number for that year is 183673.
BTW.......I guarantee you won't get it poured for that price.
I think I found the mother lode at some pretty nice prices too >>> http://compare.ebay.com/like/2209287...Types&var=sbar
Fairbanks Morse T Main Bearings Craig Barton Hit & Miss Gas Engine Discussion 4 04-02-2017 08:02:30 AM
46 JD A, Is it okay to use used main bearings? SlantdashA Antique Farm Tractors 8 11-21-2012 01:40:02 PM
main bearings 6hpMarty Antique Engine Archives 2 08-31-2004 12:21:55 AM
JD E main bearings Jim Moody Antique Engine Archives 2 03-17-2001 10:21:02 PM
main rod bearings Warren Hall Antique Engine Archives 5 03-28-2000 09:44:56 PM
