Welding Shop
225 lincoln welder
this thread has 5 replies and has been viewed 1294 times
Old 12-23-2015, 02:04:21 AM
circuitman circuitman is offline
Default 225 lincoln welder
hi guys picked up the above at an auction & the amperage switch is stuck. how is the best way of getting it working again?
Old 12-23-2015, 07:04:56 AM
oldgoat 47 oldgoat 47 is offline
Default Re: 225 lincoln welder
I would say pull off the case and make sure the contacts aren't welded first. Then a bit of lubricant down the switch shaft should do the trick.
Old 12-23-2015, 05:29:45 PM
THANKS old goat! i was thinking along the same line, just hope none of the contacts are welded.can't even work on it due to the rain. my shop is so full of junk that i can't get it in the door.
Old 12-23-2015, 08:57:44 PM
try pushing the selector in a little when turning. Mine has to be pushed in before it will turn. a little lubrication wont hurt either.
The Following User Says Thank You to slip knot For This Post:
Old 12-24-2015, 02:56:57 PM
well the good news is got it to turn, but i don't know the inside contact condition.will add some lube to it as it defitenly needs it. THANKS AGAIN for the ideas!
Old 12-24-2015, 09:39:35 PM
cleaned the contacts up good & the selector still turns a little tight but belive it'll work ok. gotta order new cables the old ones are shot, not to mention the stinger & ground clamp.
Old Lincoln Welder model k rumely Welding Shop 16 05-14-2013 12:34:10 AM
Lincoln 101 welder giacamo Welding Shop 2 10-22-2008 11:00:05 PM
OT-old lincoln welder Farmall Welding Shop 3 05-24-2008 10:14:54 AM
Old Lincoln welder - need help Ibrahim Abbas Welding Shop 3 03-25-2008 09:28:19 AM
Lincoln Welder Todd Branch Welding Shop 2 11-14-2000 08:46:06 PM
