Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Antique Bi-Polar Motors and Generators
Antique Bi-Polar Motors and Generators Early motors and generators.
General Electric Type MP4 1-1200 Form B
this thread has 8 replies and has been viewed 887 times
Old 05-28-2019, 12:35:21 PM
Vinnie317 Vinnie317 is offline
Default General Electric Type MP4 1-1200 Form B
I have a General Electric Continuous Current Generator Type MP4 1-1200 Form B Serial #121978 direct coupled to a General Electric type GM 27 two cycle Form B7 engine. The latest patent date is 1902.
It was installed at my summer camp on Lake Ontario in 1923 to run the electric lights and did so until 1934.
Does anyone have any information on this machine? It turns over freely and I would like to get it running
Old 05-28-2019, 07:43:24 PM
Default Re: General Electric Type MP4 1-1200 Form B
Sounds neat! Got any photos?
Old 05-29-2019, 07:45:07 AM
Some Pictures of GE MP4. There is a Fuller & Johnson NC in the background, it runs the water pump for the camp, this engine runs
ID:	335799   Click image for larger version
ID:	335800   Click image for larger version
ID:	335801   Click image for larger version
The Following 4 Users Say Thank You to Vinnie317 For This Post:
Old 05-29-2019, 08:18:11 AM
I do have to say that is COOL! Along with the antique rheostat and switchgear in the background...
The Following User Says Thank You to kwfiggatt For This Post:
Old 07-24-2019, 09:51:28 AM
It runs!!
Replaced broken priming petcock, put in a new spark plug, lubed up the bearings and sprayed some ether into the intake. Cranked up engine with a drill powered friction drive.
Now to clean up carb and replace some gaskets to get it to run on gasoline, can anyone suggest a gas oil mix? I have some 25:1 boat gas
The Following User Says Thank You to Vinnie317 For This Post:
Old 07-24-2019, 08:34:02 PM
Those oldies were run on a very rich oil ratio as most had bronze bearings on the rod and the mains. To be safe I'd run something heavier than modern oil. Like 30-40 weight non detergent oil at 12 or 16:1. It'll stink but you won't burn that precious oldie up.
Old 07-25-2019, 08:03:54 PM
+1 on non-detergent 30 weight. That engine will probably not like modern "2 stroke" oil
Old 08-16-2019, 11:04:40 AM
dkamp dkamp is offline
eMail NOT Working
If that engine has a sump pan with oil in it, the circumstances might be a little different... it may have been designed to run on no mix but certainly start in on an oil mix of at least 32:1, and search thoroughly for anyone who'd have information on it.
Old 09-05-2019, 01:11:37 PM
Engine does not have an oil sump so I assume needs mixed gas. Per the nameplate it is a 2 cycle engine. Main bearings are lubed by large grease cups.
Still looking for paperwork on this machine
General Electric TAB 20 kw generator. Lanzb Generators & Electric Motors General Discussion 1 03-11-2017 08:31:59 PM
R&T's General Electric DC Generator Set Jeff in PA Generators & Electric Motors General Discussion 14 12-19-2016 08:01:39 PM
1200 rpm 13 kw diesel, possibly a lister, vermont. $1200 YellowLister Onan Generators 17 04-26-2016 03:59:26 PM
General Electric Generator John Merry Generators & Electric Motors General Discussion 5 02-15-2010 02:09:10 PM
General Electric 1hp Stephen Porter Generators & Electric Motors General Discussion 0 05-25-2005 08:26:37 PM
