Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Antique Bi-Polar Motors and Generators
Antique Bi-Polar Motors and Generators Early motors and generators.
Can Someone ID this Motor/Generator
this thread has 6 replies and has been viewed 1065 times
Old 04-30-2018, 09:19:51 PM
Wallysworld Wallysworld is offline
Default Can Someone ID this Motor/Generator
Hello everyone, I am new to this forum so please bear with me. Found this interesting piece while cleaning out my dad's estate. The building belonged to a family run hardware store dating back to 1890's. We already found a vintage leather sewing machine from 1931 so who knows what decade this might be? Better yet - what is it?
The large marble piece behind the motor has two gauges that say Norton Voltmeter. There was a bunch of knob and tube wiring stuff behind the motor in front of the marble. For some reason the marble pic is upside down.
So far have not found any markings on the unit itself. Can anyone help?
ID:	309565   Click image for larger version
ID:	309566   Click image for larger version
The Following 4 Users Say Thank You to Wallysworld For This Post:
Old 04-30-2018, 10:22:22 PM
Vanman Vanman is offline
Default Re: Can someone ID this motor/generator
Ooh, that's NEAT!
That is a direct current machine. It could be used as either a motor or a generator.
These have erroneously been classified in the misInformation age as "bipolar". They are indeed two pole machines. But so are many others. A distinction without a difference, as the saying goes.
Nevertheless, and right or wrong, if you search for that term, you should find lots of information about them in general, and maybe even some information specific to yours.
Here's a baby one that I have:
https://m.youtube.com/watch?v=ML9cCZMPKXs
Keith
Old 05-01-2018, 10:02:23 AM
Vanman What is your definition of bipolar motor and dynamo. Ron
Old 05-01-2018, 11:23:44 AM
It seems to me that bipolar, in this context, means Two Pole.
So, for instance, here's another bipolar motor. This one is identical to the other except for construction of the field frame.
https://m.youtube.com/watch?v=grFDv2PLq3k
Old 05-01-2018, 01:35:46 PM
Joe K Joe K is offline
Looking similar to a Crocker-Wheeler unit of my ownership.
Mine 110VDC, 3 horsepower. Weight about the same as a modern car engine - and only slightly smaller. Here's a pix of similar.
This one at New England Wireless & Steam Museum where it has at times been used to power the incandescent bulb lighting in the engine house.
Note that I say motor - mine is rated as a motor. But generators are IDENTICAL except for the direction of energy.
Yours probably used as a generator - the panel you show seems to show output gauges and "rheostats" (variable resistors) used to control the field current (current through the large bipolar magnets) and thereby control the voltage output (and hence the brightness of lighting attached.)
Panels were frequently made of varnished wood, slate, or even "micarta" (insulating bakelight) Always located where it was dry for obvious reasons.
Joe K
The Following User Says Thank You to Joe K For This Post:
Old 05-01-2018, 03:07:50 PM
Default Re: Can Someone ID this Motor/Generator
I was thinking that his rheostat may have been to control voltage as a generator, but then again, it could have been used to control speed as a motor...
Old 08-13-2019, 10:17:36 PM
dkamp dkamp is offline
eMail NOT Working
Typically, if it's used in a motoring application, there's a handle that is used to advance the brush timing, to allow the motor to start a heavy load and bring it up to speed gradually, or even throw past center and reverse.
in a generating application, it's set with fixed brushes, and either the field current is modulated (in a DC application) or the armature current is modulated (in an AC application) and the field produces output. The hand-lever is the giveaway.
can someone look up what generator goes for my motor ehpower2 Multi-Cylinder Stationary Gasoline Engines and Power Units 1 05-08-2015 03:52:51 PM
Generator or Motor? Junkologist Generators & Electric Motors General Discussion 18 08-12-2014 11:59:51 AM
GE motor/generator? joder Generators & Electric Motors General Discussion 8 09-13-2013 09:41:12 PM
Motor to Generator??? Randall Marquis Generators & Electric Motors General Discussion 6 06-20-2006 09:46:50 PM
Motor as Generator jdunmyer Generators & Electric Motors General Discussion 15 02-26-2005 08:34:35 AM
