Smokstak Down Under
McCormick Deering 1.5 /3 HP engines - Mixers
this thread has 6 replies and has been viewed 549 times
Old 04-21-2019, 07:07:28 AM
Jon Gregg Jon Gregg is offline
Default McCormick Deering 1.5 /3 HP engines - Mixers
Hi, I`m rebuilding two overstrikes and I have decided to make the fuel needles to fit the homemade siphons ( Both engines have corrosion in the mixers and are Kero/water units). The question is..the jet orifice size require to feed the engines. Has anyone done this before and can offer advice? Thanks Jon. (Adelaide)
Old 05-08-2019, 07:20:04 AM
Default Re: McCormick Deering 1.5 /3 HP engines - Mixers
Really...nobody has ever checked the "jets"
Old 05-08-2019, 08:03:53 AM
I don't think the hole size is critical. Most orifices that I have seen are around a 1/16". The needle valve will control the amount of fuel.
Old 05-08-2019, 08:16:42 AM
Thanks Bill, I sort thought that might be the case +/- ...I drilled the jets to .035. I`ll make a new set to your suggestion. Thanks again. Regards Jon.
Old 05-08-2019, 04:41:13 PM
Scotty 2 Scotty 2 is offline
Nope. Never measured them. Just cleaned them and reused. To me it would be more critical to have those fibre washers placed correctly to stop fuel been sucked in, the butterfly to seat correctly and for the butterfly shaft to be not worn.
The taper of the needle is even probably more important then the orifice size.
I do know the hole is pretty big. Lot bigger then .035.
I've been cleaning the shed and a 1 1/2hp is at the front at the moment. I'll take the mixer screw out and see what size drill goes in for you. Hopefully I'll have a small drill bit long enough.
Cheers Scott
Old 05-08-2019, 06:29:11 PM
Went to the shed and found the 1 1/2hp HT engine. Looked to the side of it and found a 3hp over strike. Looked out under the back patio and found other 1 1/2hp HT and another 3hp over strike. They all had a .070" or 1.82mm diameter bit of wire go right through without any effort. All the smaller drill bits weren't long enough so a bit of wire was the go. 1.5mm staino TIG wire was all sloppy so a bit of plain HT fencing wire was the go.
It seems like the 1/16th guess Bill has was pretty bloody close
Cheers Scott
PS: all keen now to give the 3 hp engines a run.
Old 05-09-2019, 10:41:00 AM
Thank you all sooo much. I`m new to restoring old engines, but when you don`t have a 'reference' to work with..well it`s a pain. I appreciate anyone who goes the yard. Cheers all. Jon.
Remmel Mixers with engines B.L. Rodenkirch Antique Gas Engine Discussion 1 01-24-2016 03:51:55 AM
IHC vs McCormick Deering M Engines jboyer1028 Antique Gas Engine Discussion 13 03-11-2013 02:30:00 PM
McCormick Deering 1-1/2 Widgeon Antique Gas Engine Discussion 3 09-19-2012 12:05:37 PM
Two McCormick-Deering engines and the WHAT is it? Denis Rouleau Antique Gas Engine Discussion 6 10-18-2011 11:11:36 PM
McCormick Deering Engines John Taylor in Tennessee Antique Engine Archives 0 07-01-2002 04:57:32 PM
