Smokstak Down Under
Loctite
this thread has 26 replies and has been viewed 1236 times
Old 06-01-2019, 08:20:01 PM
typak typak is offline
Default Re: Loctite
Originally Posted by Winchester View Post
Yes well I once had occasion to repair a mans dentures with Araldite.
Well Winchester, to my understanding that procedure can sometimes have the added side affect of causing lockjaw, as we know not a bad thing in some cases?
Old 06-01-2019, 08:49:34 PM
Scotty 2 Scotty 2 is offline
Default Re: Loctite
And then you have the opposite of locking type Locktites. Never-seize. I love the stuff. It doesn't leak unless I put a hole in the pot.
Cheers Scott
Old 06-01-2019, 10:14:43 PM
Fred Van Hook's Avatar
Images: 480
Photo Re: Loctite
Just open a bottle of Neverseize...
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following 2 Users Say Thank You to Fred Van Hook For This Post:
  #24
Old 06-02-2019, 12:09:45 AM
Default Re: Loctite
Just think,that poor guy died because he was poisoned by that paint for the movie!
I use the copper antisieze,it makes just as much mess!
I use the Loctite Bearing and Sleave retainer on Briggs and stratton valve guides in these over head valve engines when they decide to scoot and prevent the valve from opening. I remove them,dimple them with a sharp punch,coat them with the retainer chemical and drive them back in. 6 machines are still running today with that repair.
  #25
Old 06-02-2019, 01:01:05 AM
AussieIron AussieIron is offline
Default Re: Loctite
I have used Molybond anti seize lubricant. Messy too in the tube, sticks like sh!t to a blanket, and does the spray can version stink!
Old 06-02-2019, 01:34:04 AM
Default Re: Loctite
So why is it that the stuff you want to remain stuck gets loose and the stuff you want to stay loose gets stuck tighter then a ducks bum?
I hate Murphy.
  #27
Old 06-02-2019, 06:07:33 AM
E27N's Avatar
E27N E27N is offline
Default Re: Loctite
Originally Posted by Scotty 2 View Post
Hello all
Does anyone remember the bottle of goop that Holden recommended to be used on head bolts on Holden engines? It was used to seal the bolts etc that screw into the water jackets. I have a bottle here (if I remember where it is. I got to clean up) I still like to use on head bolts that go into water jackets.
Cheers Scott
Mmmm yea, cleared the sinuses fairly well when you opened the tin
I love the smell of 515 in the morning...
Gasket Sealer and Loctite on bolts? enginesilo Maytag Engine Collectibles 10 12-10-2012 11:15:18 PM
Removing high strength loctite lester Antique Engine Archives 7 03-26-2003 12:54:15 PM
