Welding Shop
Herucles IXB Lincoln SA 200 Welder
this thread has 3 replies and has been viewed 1188 times
Old 03-05-2016, 10:05:38 PM
lynnlpitts lynnlpitts is offline
Default Herucles IXB Lincoln SA 200 Welder
I'm trying to get my father-in-laws SA 200 with Hercules IXB going after twenty years of sitting.. freed it up and cleaned water cooling.. but now it is leaking from the water pump seal...How do you remove the water pump...I assume you first take mag(FM) off the ....? Thanks! Lynn (lynnlpitts@hotmail.com)
Old 03-05-2016, 10:42:41 PM
mschreiber mschreiber is offline
Default Re: Herucles IXB Lincoln SA 200 Welder
maybe some more info here
http://weldingweb.com/forumdisplay.php?23-Lincoln
The Following User Says Thank You to mschreiber For This Post:
Old 03-05-2016, 10:46:35 PM
Welcome to STAK.......
I've moved your question to the appropriate forum.
Old 03-06-2016, 03:26:25 PM
If that unit has a packing nut that compresses string-graphite type packing or a split-circle type packing, it might just need a little time to soak up/expand---sitting for long time they tend to dry out...
Or it just might need some new packing material or a new packing piece pushed in, if the packing nut screws completely out and slides back on the shaft...
Or even just a little CAREFUL "snugging up"---but it'd be better to back nut off and clean threads first, after sitting so long; you don't want to strip or crack the housing by overtightening...
The Following User Says Thank You to Bud Tierney For This Post:
Lincoln H2 DC Welder. Combustor Welding Shop 6 06-25-2014 04:01:41 AM
Lincoln SA 200 welder: please help maddenfarms Welding Shop 8 04-28-2010 11:46:54 PM
OT-old lincoln welder Farmall Welding Shop 3 05-24-2008 10:14:54 AM
Old Lincoln welder - need help Ibrahim Abbas Welding Shop 3 03-25-2008 09:28:19 AM
Lincoln Welder Todd Branch Welding Shop 2 11-14-2000 08:46:06 PM
