Welding Shop
Miller Tig / need Capacitor
this thread has 6 replies and has been viewed 1523 times
Old 03-25-2016, 09:44:13 AM
DaveHC DaveHC is offline
Default Miller Tig / need Capacitor
Ttrying to help a friend find a capacitor for his older Miller Tig welder . The part number is 204933 , and replacement numbers are 096761 & 031602 . So far he has found one for around $100 + , trying to find something more reasonable . Thanks for any help .
Old 03-25-2016, 11:32:51 AM
G.M.Johnson G.M.Johnson is offline
Default Re: Miller Tig / need Capacitor
You can try these guys http://www.rficorp.com/MICA2.html and ask for part number ZD2B123C252. This capacitor is rated for slightly higher voltage and is .0025 uf. Don't know if it is larger or smaller in overall size then your original. It also mounts from the bottom and does not have screw terminals for hook up.
Old 03-25-2016, 03:10:55 PM
zombierspndr zombierspndr is offline
Only things that matter with a capacitor:
1. rated for the same or higher voltage
2. capacitance is the same
3. it's the same type(electrolytic, mica, etc.)
4. it's the same or lower percentage of deviation. In other words, if you had a 1% cap, you wouldn't replace it with a 20%. You could replace a 20% with a 1% though it would be more expensive.
I found this though. http://www.plccenter.com/Buy/MILLER%...20PARTS/096761
Old 03-26-2016, 10:16:15 AM
Except it's too bad PLC center is out of stock, and the last price update was back in 2012! As far as total value is concerned, it all depends on the inductance of the HF transformer. Not knowing what it is in this case you very well may be able to use a cap with a 50% greater or less value, .002 verses .0025. If the price is right I would for sure try it out and see. For my own knowledge I did send a email for a price quote just to see how much Miller is marking up the pricing.
Old 04-03-2016, 12:16:39 PM
dkamp dkamp is offline
eMail NOT Working
This capacitor is for the HF generator's spark-gap oscillator circuit.
IF you were building a proper oscillator-driven transmitter, and was using this as the DC blocking capacitor of the high-voltage plate circuit, you would HAVE to have it in proper spec to tune the transmitter to some specific frequency range.
Since this is a spark-gap HF generator, the capacitance isn't nearly as critical... you could be somewhere lower or higher by quite a bit.
I don't recall what I changed my goo-bleeding caps out with, but it was whatever I had in my junk box that was near the pF. It probably got liberated from some piece of scrapped out hollow-state technology two dozen years ago. Since the stock ones die a disgusting death, I went to higher voltage. Never hurts to go higher in voltage.
A higher capacitance will lower the general frequency, while a lower capacitance will raise the general frequency. Note that when adjusting the arc gap, you will also be varying frequency, and besides the primary frequency, these oscillators generate overtones from hell, so if you put it on an o'scope for a look, you'll see a picture that looks more like a portrait of Betsy Ross on a Jimi Hendrix album cover, than an oscillator waveform. You could replace that capacitor with a plastic bottle cap sandwiched 'tween two quarters, and it'd probably work just fine anyway...
So slap something close in, shoot for 5kv and anything remotely close, push the pedal, hear the hiss, and look for the bright light at the end of the tungsten tunnel...
Old 04-03-2016, 07:50:55 PM
willyjasper willyjasper is offline
I have a capacitor, maybe 2. PM me if your interested
The Following User Says Thank You to willyjasper For This Post:
Old 04-04-2016, 09:12:08 AM
Thanks , I PM 'd you .
2.0 P.E capacitor Kevin New Mexico Onan Generators 5 03-24-2015 11:34:48 PM
Condenser/Capacitor thiggy Maytag Engines and Collectibles 15 05-01-2013 09:10:05 PM
25mfd capacitor PRoot Generac Generators (SEARS, etc.) 8 02-10-2012 08:48:25 PM
Which capacitor for my K-W flasks Magnetos, Ignition Coils and Spark Plugs 7 08-21-2008 10:26:38 AM
.1 mfd Capacitor Tom Jamboretz Onan Generators 5 04-24-2005 12:31:09 AM
