Smokstak Down Under
Rookie with IHC M magy Question
this thread has 39 replies and has been viewed 1735 times
Old 06-13-2019, 06:56:12 AM
Dobbo56 Dobbo56 is offline
Default Rookie with IHC M magy Question
Hi all
Alot of work been going on with the M, got replacement parts for missing or broken one now for the magy.
This engine has an American Bosch FX1- ED1 high tension magy.
Took the spark plug out and layed it on the hooper with lead attached, spun the flywheel and no spark, so took the plug out and held the cable while spinning the flywheel, just a bit of a tingle, so I bit the bullet and remove it from the engine and took it into the shed, cleaned it up, points, cable contacts, while doing this on my metal top bench, spun the cog and whoa what a jolt, so it must be working, so the plug must be dead. My problem is the cog has one tooth half missing and at least 4 others damaged, where would I get a 36 tooth cog from, and a spark plug old one is a Champion D22 18mm been watching ebay.
Old 06-13-2019, 07:34:17 AM
Famous Fitter Famous Fitter is offline
Default Re: Rookie with IHC M magy question
Hi Dobbo56,
New mag gears can be obtained out of the USA from a few suppliers for all sizes of the the M type engines.
Some Auto parts shops still carry 18mm champion plugs and I have also bought them in NGK too- can’t remember the number.
All my M type engines have the 7/8 unf plugs in them.
cheers Justin
The Following User Says Thank You to Famous Fitter For This Post:
Old 06-13-2019, 11:49:25 AM
Default Re: Rookie with IHC M magy Question
The proper plug is 7/8" - 22mm. Champion actually made a special plug for the Ms. They come up on evilbay from time to time.
Old 06-13-2019, 12:20:52 PM
Dobbo56 I can make that gear for you out of one of my cast iron 3 HP M gears I have the gears available for the 1 1/2 and the 6 with the tapered bore but not the 3 as a standard stock Idem PM me if your interested Thanks, Mitch
Old 06-13-2019, 04:14:26 PM
Scotty 2 Scotty 2 is online now
Hello Mr Dobbo
Any pictures of the gear and plug?
The gear may be usable pending damage. They don't need much to spin the magneto.
Also the plug maybe an older 'pull apart and clean' plug.
Is your engine a converted low tension or is it one of those fairly rare factory rotary HT magneto engines? I can't remember your particular engine....sorry.
Cheers Scott
Old 06-13-2019, 07:27:48 PM
Hi al thanks for comments.
Scotty
As far as I know it is the original magy, see photos.
Since my original post I have rebuilt the mixer, fuel pump, made a new fuel tank, got a replacement exhaust valve rocker arm and built a trolley. Get the magy going and hopefully it wiill go.
Cheers
Dobbo
ID:	337088   Click image for larger version
ID:	337089   Click image for larger version
ID:	337090   Click image for larger version
ID:	337091   Click image for larger version
The Following User Says Thank You to Dobbo56 For This Post:
Old 06-13-2019, 09:09:04 PM
Mick's Avatar
Mick Mick is offline
Unfortunately that gear is junk as u can see the pot metal is coming apart from age. Better off getting a new replacement
The Following User Says Thank You to Mick For This Post:
Old 06-15-2019, 02:59:24 AM
cobbadog cobbadog is offline
I go to my local Repco store for my old plugs and where possible use NGK but I have had to settle for a mongrel champion plug for one engine but it is still working so there it will stay.
Someone here may well have a gear sitting about in the shed and maybe Rob.S might have one in his selection of fine cast products scattered about his property.
Old 06-15-2019, 07:21:18 AM
Thank for that info Cobbadog, I should of thought about RobS, I got the exhaust rocker arm from him, might even go for a drive ovr and meet him. Will be going through your local in a couple of weeks on our way to our van.
Cheers
Dobbo56
Old 06-16-2019, 07:42:38 AM
Rob and Julie are wonderful people and if they can help they certainly will. Where is your van?
We will be going to the Yesteryear Truck show mid July then if I pull my finger out our Cropmaster will be a finished long term project ready for the Rusty Iron Rally. Sand blasting was done today.
Old 06-16-2019, 11:57:49 PM
I have only spoken with Rob on the phone but was very helpful, haven't contacted him yet about the maggy cog.
Our van is at Nth Haven, we try to get there very 2 or 3 weeks for a couple of days. I'm hoping to get to the truck show at Wauhope as well, might be able to meet you there.
Old 06-17-2019, 07:34:27 AM
Nice hidy hole there. We sometimes escape to Stockton Beach van park and we like it there too. We head to Wauchope on the Friday morning and back home after lunch.We are taking Dess' HRH Sarah Ferguson, her grey fergie so we wont be far away from that.
Will you be taking anything up? Sometimes RobS turns up at this rally too.
Old 06-18-2019, 08:20:17 AM
Well I have removed the cog from the maggy and it really is had it see photos.
ID:	337405   Click image for larger version
ID:	337406   Click image for larger version
Old 06-18-2019, 06:01:31 PM
Crappy pot metal tends to do that (zinc alloy). if you dont have any luck locally, Hit and Miss Enterprises sells new gears on this side of the pond.
Old 08-20-2019, 11:03:16 PM
Sent the maggy away to the Maggyman in Naracootre SA for complete rebuild, wont get it back for awhile.
Coils will be rewound, magnets remagnetised and new 36 tooth steel drive cog, not much dearer than buying a new cog from the USA ( cog US$138.85 + freight US $85.90). Repairs should be completed Thursday 22nd Aug but I'm away at van, ready to go to the Rusty Iron Rally 31st Aug / 1st Sept in Macksville. Then home and reinstall and timing hopefully the M will then go.
Old 08-21-2019, 06:48:35 AM
At least you are making progress with it Paul. We will catch up at the Rally. We are taking Flo the Farm Pumper to run in the record attempt and I am still hopeful that the Cropmaster will be finished too. We arrive on Friday and head home Monday. This year we booked to go to the Rally diner again.
Old 08-21-2019, 08:18:26 AM
Have been doing other thing towards the end of this M project, been making wheels for a trolley as finding any on evil bay of the right size is not so easy. From what info I can find on line the orginal trolley has 9" front and 12" rear wheels, the best I can do is 8" front from an old oxy bottle and 13 1/2" rear. Also added a fuel tank and hopper drain tap and pipe.
We will at the rally on Saturday, see you there
The Following 2 Users Say Thank You to Dobbo56 For This Post:
Old 08-21-2019, 05:40:57 PM
Hello Mr Dobbo
It looks as though things are happening.
Did you find the size of the trolley for your little M type?
If you want a set of stencils to do the writing that they had on the side of the trolley, just PM me your address and I'll make a set and post.
Cheers Scott
The Following 2 Users Say Thank You to Scotty 2 For This Post:
Old 09-19-2019, 04:59:01 AM
The maggy is back from the Maggyman completely rebuilt and back in the M, hope timing mark are lined up.
TOMORROW IS THE BIG DAY!!!!!!!! :
Then onto the transporter, wheels nearly done, then off to our wood heap
Cheers
Dobbo56
Old 09-20-2019, 04:20:40 AM
NO GO
Three splutters
Got fuel, got spark and timing correct
Time to bang the head against the wall
YC Stover needs carby, fuel pump and lever, igniter and magy macdonald Smokstak Down Under 3 04-28-2019 01:00:26 AM
Rookie with IHC M Dobbo56 Smokstak Down Under 34 04-08-2019 06:52:53 AM
4.0 CCK Rookie mistake DAP Onan Generators 6 08-08-2008 08:24:11 AM
Waterloo Boy igniter + magy bracket Bill Ellis Magnetos, Ignition Coils and Spark Plugs 0 04-16-2008 04:58:16 PM
