kellogg compressor pulley size
this thread has 6 replies and has been viewed 2548 times
Old 07-02-2012, 06:05:45 PM
no spark no spark is offline
Default kellogg compressor pulley size
Hello, i just picked up a kellogg model a320a air compressor that is missing the motor. All i can find out about it is that it came with a 1 1/2 hp motor , now i need to know the pully size that came on the motor, any help would be helpful. Thanks
Old 07-03-2012, 10:37:38 AM
David K David K is offline
Default Re: kellogg compressor pulley size
What size pulley is on the compressor? How many RPM does the motor that you want to use spin?
Dave
Old 07-03-2012, 05:56:13 PM
I won`t be able to get that info until this weekend its two hours away from my house. As soon as i get the info i will post it. Thanks again.
Old 07-04-2012, 12:07:17 AM
930dreamer 930dreamer is offline
Look here!
http://www.aircompressorpartsonline....p0uvon82ucmtr0
Old 07-04-2012, 05:44:34 PM
930dreamer thanks for the web site will come in handy if i need parts, i had a buddy go and measure for me, the dia.of the pulley on the pump is 13 3/4" and the rpm on the motor is 3450rpm it came off a compressor that said 2hp on it, tag on motor says hp - stl.00 thanks for any help.
Old 07-07-2012, 09:58:55 PM
Use a 2 3/4" pulley on the motor. That will spin the compressor around 690 rpm, which is just about perfect.
Dave
The Following User Says Thank You to David K For This Post:
Old 07-08-2012, 07:00:33 PM
Thanks for your help, i will pick one up tomarrow.
Help on pulley size ratios Tom Kilgore Generators & Electric Motors General Discussion 7 06-14-2011 07:23:34 PM
New 6hp Briggs pulley size opus Small Air Cooled Gasoline Engines 2 11-01-2009 10:07:43 PM
Finished size for Aermotor pulley Ray Cardoza Hit & Miss Gas Engine Discussion 2 11-25-2008 03:39:21 AM
Pulley size-somebody knows ! Gilli43 Steam Stationary Engines, Traction Engines 10 04-24-2008 09:27:04 PM
IHC Clutch Pulley What size does it Fit? Gasengin Hit & Miss Gas Engine Discussion 10 10-25-2007 08:14:21 PM
