Onan CCK oil filter retrofit
this thread has 7 replies and has been viewed 2249 times
Old 12-30-2012, 05:56:04 PM
marvgarr marvgarr is offline
Default Onan CCK oil filter retrofit
can you put an oil filter on an old cck that did not have an oil filter and were would it plumb into
Old 12-30-2012, 07:02:28 PM
David C David C is offline
Default Re: Onan CCK oil filter retrofit
Unless you feel like doing major modifications to the oil passages in the block, you can only add a bypass oil filter system. You can tee in the oil pressure line at the oil pressure switch and you will need to drill and tap the oil base for the return line.
David C.
Old 12-30-2012, 07:53:10 PM
Billy J Shafer's Avatar
I would check with Max. Since he just bought out an old Onan dealer. He may have the sheet on the Onan option kit for the CCK.But if I remember correctly. It is like David posted.
Old 12-30-2012, 10:36:38 PM
Ted_Cool Ted_Cool is offline
Bypass works fine. No need to drill the oil base - just put a nipple and a tee into the oil drain plug hole.
The Following User Says Thank You to Ted_Cool For This Post:
Old 12-30-2012, 10:48:59 PM
Motorhead's Avatar
I would think you would need some sort of flow restricter on the oil filter line to not take all the oil flow to the engine.
Old 12-31-2012, 12:01:50 AM
RETCPO RETCPO is offline
Bypass oil filter as has been told...
good read
http://www.smokstak.com/forum/showthread.php?t=101816
Old 12-31-2012, 02:06:04 AM
What kind of filter assembly can I use will a spin on filter housing with a special filter or are there other ideas I am not worried about a factory system unless they still make a kit for it
Old 12-31-2012, 06:39:50 AM
http://www.smokstak.com/forum/showthread.php?t=99726
Standard spin on filters do not have the micron filtration level required for the bypass system see above link for more links and some background
Onan MEP 016B Military Fuel Filter & Air Filter (Help) Doogdoog Onan Generators 12 08-17-2015 07:38:11 PM
Onan MCCK 6500 how to add a full flow oil filter or bypass filter? sdowney717 Onan Generators 9 04-20-2012 10:31:40 AM
Onan 15JC retrofit for Power Tronics uVR501 help needed! kilawat Onan Generators 4 02-16-2011 03:24:22 PM
Changed oil/filter--air filter Onan BGE now it will not start T Macgown Onan Generators 5 10-11-2009 05:29:10 PM
Help with onan engine retrofit ChrisR Onan Generators 4 02-17-2006 02:39:49 AM
