Welding Shop
Lincoln SAE 300 with Bedford engine
this thread has 10 replies and has been viewed 3162 times
Old 11-09-2014, 01:21:27 PM
97fordguy970 97fordguy970 is offline
Default Lincoln SAE 300 with Bedford engine
Hi, first I want to say this site is awesome. I love engines and machines. I just bought this Lincoln SAE 300-220. It has the four cylinder Bedford engine. I am trying to find a parts supplier for the engine. It runs great but has a couple of fuel leaks. One injector leaks and a weep hole between the timing case and the injector pump leaks intermittently on cold start up. Any resources or info is greatly appreciated.
Old 11-10-2014, 02:16:01 AM
Default Re: Lincoln SAE 300 with Bedford engine
Down at the very bottom of the page are several earlier Bedford engine threads, and more will come up on search here...
Bedford was GM's Brit operation, and while popular there (and, I think in AU) apparently not much over here...
Googling Bedford diesel will bring up a lot of stuff, including at least one supplier but only of specific models...
My apologies if this is all stuff you already know...
The Following User Says Thank You to Bud Tierney For This Post:
Old 11-10-2014, 11:00:54 AM
oldgoat oldgoat is offline
Email NOT Working
I have a manual which probably covers what you want to know I could scan the relevant pages
The Following User Says Thank You to oldgoat For This Post:
Old 11-29-2014, 10:08:38 PM
Hi, thanks again and I am wondering which manual you have. I have the IM266.
Old 11-30-2014, 09:48:00 AM
Email NOT Working
The Manual I have covers the 220 cu.in. diesel with a sims injection pump and vacuum governor. Its the automotive version which has the pump driven by an extension shaft off the compressor. I get parts from Turkey he has a site on the net btu34 is his name I think.
Old 01-10-2016, 01:47:24 PM
Hi, sorry so long my Bedford has the CAV DPA injection system. I am actually looking for info on that now. She just quit running, no fuel to injectors. Thanks, Tom
Old 01-12-2016, 06:48:35 PM
mean mean is offline
The engine supplier that has everything is carlin america.
Hope this helps. I had a sam 400 with a 220 bedford. Great engine.
Mine had a fuel leak at front seal from weep hole took pump to a shop n they fixed the seal pretty reasonable. Although years ago. I think the pump was a CAV pump. Other places wanted to just go through the whole pump for big money. Wasnt necessary. Pump worked fine
Old 01-13-2016, 08:39:22 AM
oldgoat 47 oldgoat 47 is offline
This video should is better than a manual for the DPA pump. the only disagreement I have with it is I would clean of the exterior of the pump first
https://www.youtube.com/watch?v=h26p78YZIr4
The Following User Says Thank You to oldgoat 47 For This Post:
Old 01-31-2016, 02:04:12 PM
Thanks alot that video is great.
Old 02-01-2016, 01:15:15 AM
cobbadog cobbadog is offline
Yep Bedford stuff is UK built and available in Australia as well. Good old Bundy has made so many videos you just could not sit and watch them all as I haven't enough time left but he certainly has helped a lot of people.
I too would have cleaned off the outside as well before pulling any pump apart.
Old 02-03-2016, 12:10:06 AM
I scrubbed the whole thing before I cracked a bolt loose. In the middle of the rebuild have a seal issue that I hope comes out ok.
Bedford Model 1500 Air Cooled bigGURN Small Air Cooled Gasoline Engines 2 09-27-2012 08:25:55 PM
GM Bedford diesel Delco Military genset - help please mhinkle Military MEP and Aircraft Gen-Sets 4 08-24-2011 02:09:49 AM
Need Help Finding Bedford Head Gasket Rick McKay Vintage Diesel and Oil Stationary Engines 2 10-27-2008 05:10:15 PM
Bedford trucks? Jordan Antique Autos and Trucks 5 03-13-2008 01:30:21 PM
bedford gas engine, bedford indiana ??? Nathan Grissom Small Air Cooled Gasoline Engines 3 02-27-2007 10:44:26 PM
