Welding Shop
MOSA Italian DC Welder
this thread has 4 replies and has been viewed 2444 times
Old 12-16-2014, 12:45:43 AM
debe debe is offline
Default MOSA Italian DC Welder
Looking for any information on this welder, in particular a circuit diagram. It has one welding socket missing. The engine is a 2stroke & runs fine.
ID:	213568   Click image for larger version
ID:	213569   Click image for larger version
ID:	213570   Click image for larger version
Old 12-16-2014, 12:47:46 AM
Default Re: MOSA Italian DC Welder
2 more pics.
ID:	213572   Click image for larger version
Old 12-21-2014, 03:59:25 AM
Hello debe,
Does your welder actually put out DC current? There is no indicatoin on the nameplate that it does, and the only Mosa welder that I ever used many years ago produced high frequency AC power. Welded very nicely, but you could hear the arc whistle and sing as you welded. Someone here may recall their AC welders and who sold or serviced them. Regards,
Combustor.
The Following User Says Thank You to Combustor For This Post:
Old 12-22-2014, 06:29:16 PM
Will get back on that, noticed the spec plate has freq 1400-2600 Hz so you may have a point there.
Old 10-21-2015, 04:20:10 AM
Will share this link for the welder manual (compliments of radvasar) http://www.mosaenergia.com/assets/ma...%20CHOPPER.pdf.
Italian made engine Marv Small Air Cooled Gasoline Engines 22 12-02-2014 11:39:29 PM
italian boat motor damnflies01 Antique Marine Engines and Outboard Motors 0 10-14-2014 02:16:11 PM
Italian 1HP Condor A1 starts but won't run JAM Small Air Cooled Gasoline Engines 0 12-01-2012 02:14:05 AM
Italian Hit and miss anyone? Gavin Bedggood Antique Engine Archives 1 06-07-2003 12:25:36 PM
