Delco-Remy/AC-Delco Dist/Gen/Starter Etc Numbers
this thread has 0 replies and has been viewed 2071 times
Old 01-05-2015, 05:09:03 PM
Default Delco-Remy/AC-Delco Dist/Gen/Starter Etc Numbers
While looking up points etc for the 1111775 distributor, dug out an
"AC-Delco New/Reman'f'd Alt/Gen/Starting Motors-New Dist's" catalog #1A-100 1988...
This was whole units only, no internal parts...
In the Alt/Gen/Starter sections had three columns: "original" number (1100837) "new" number (1100842) and "reman" (completely different type of number)...
Some numbers were only slightly changed (1100837 to 1100842)
Some were considerably changed(1100882 to 1105360)
Some weren't changed, "orig" and "new" staying the same number...
In the Dist section a much smaller percentage of numbers were changed, many "orig" and "new" the same...(no "reman" dist's)...
Did GM and/or AC-Delco (AC-Delco, Gen Mtrs Corp, Detroit) simply assign new numbers for some reason, or were these later models that replaced/superseded the earlier ones, or what???
No, I didn't find 1111775 where it usually shows up, which means there're 9 pgs of non-pass to eyeball and if not there 23 pgs pass cars to eyeball...maybe I'll try Googling...
---------- Post added at 04:09 PM ---------- Previous post was at 03:58 PM ----------
OOPS---yes, did find 1111775---number not changed.
Delco Remy Starter/Generator Serial Numbers Kurt 396 Generators & Electric Motors General Discussion 6 03-29-2018 04:33:41 PM
Delco Remy 1998413 Starter ID Dempster Military MEP and Aircraft Gen-Sets 8 08-17-2011 07:03:01 AM
Delco Remy Volt. Reg. & Starter/Gen. Jim Nixon Garden Tractors and Mowers 1 08-21-2008 10:00:33 AM
Parts for OLD Delco Remy Generator and Starter. Evan W Hit & Miss Gas Engine Discussion 2 10-31-2006 12:02:01 AM
Delco Remy Generator CScheda Small Air Cooled Gasoline Engines 7 08-23-2005 07:40:56 AM
