Welding Shop
Belco Scott gas powered welder
this thread has 3 replies and has been viewed 3906 times
Old 01-17-2015, 11:27:07 PM
F. Moore F. Moore is offline
Default Belco Scott gas powered welder
I have a 200D Scott welder made by Belco here my farrier dropped off for me to take a look at. It runs but when you try to strike an arc it just sticks the rod. He's had the alternator off and checked as well as the voltage adjust pot. I'd like to find a wiring diagram or info it before I start taking a shot in the dark and unsoldering the diodes checking them.
Old 01-17-2015, 11:36:25 PM
Default Re: Belco Scott gas powered welder
Here's a picture of the data plate. I cannot get the rest of the picturse to load.
Old 01-18-2015, 11:20:41 AM
RSCurtis RSCurtis is offline
Be sure the drive belts(s) are tight.
Old 09-12-2015, 09:44:47 PM
zombierspndr zombierspndr is offline
I know this is an old thread, but as far as I know, they used a standard Delco alternator on those. I would check the open circuit voltage and then the rectifier diodes. If it's not the diodes, then the rotor or stator may be shorted. It's possible to have a shorted set of windings in the stator and the alternator still produce power....just not as much as it should.
I've never been able to examine a scott welder in person, but from what I understand from reading about them is that they're very similar to "weldernator"(google it) conversions of 10 and 12si Delco alternators. I'm not educated enough to tell you if those alternators are factory(Delco) wound in Wye(most likely) or Delta configuration, but Scott probably used Delta wound to get higher amperage and lower open circuit voltage for safety.
Miller Welder Onan powered AussieIron Onan Generators 6 07-24-2014 08:52:32 PM
No arc on a Lincoln gas powered welder std Welding Shop 7 10-31-2012 07:59:44 AM
6cyl powered welder.. JIMnWV Welding Shop 10 01-10-2012 07:47:47 AM
help with flat head powered welder buckcreek Welding Shop 10 03-08-2007 09:00:44 PM
I need help with an Onan powered Gen/Welder jwallen Onan Generators 2 12-04-2006 04:37:49 PM
