Welding Shop
new to me welder -need manual Hobart Combo AC/DC
this thread has 5 replies and has been viewed 2052 times
Old 04-17-2015, 08:55:26 PM
Jeff in PA's Avatar
Jeff in PA Jeff in PA is offline
Default new to me welder -need manual Hobart Combo AC/DC
I picked up a Hobart Combo AC/DC stick/ TIG/ Plasma cutter last week off a local guy on CL. Wth the exception of the plasma cutter ( bad cable )cutter, it's ready to go. All cables, plenty of consumables for the TIG torch and a large milk crate of welding, cutting and hard facing rods.
Anyone have access to a manual?
Here's the welder.
info plate
Old 04-18-2015, 12:54:29 AM
Default Re: new to me welder -need manual Hobart Combo AC/DC
Jeff
Do a search for my name and Hobart. It should be back about 5 years or so.
There will be a name and phone # for the Hobart Guru.
Hope this helps,
Jim
The Following User Says Thank You to Jim Tremble For This Post:
Old 04-18-2015, 07:42:51 PM
Jeff in PA's Avatar
Originally Posted by Jim Tremble View Post
Jeff
Hope this helps,
Jim
This guy?
BTW, if anyone needs help on a Hobart welder, call-------
Mike
C&M Welding
419-584-0008
This guy knows everything about Hobart.
Thanks for the replies and help,
Jim
It was thread for the welder in the generator section.
Thanks,
Jeff
Old 04-18-2015, 10:52:41 PM
I've had good luck with calling Hobart directly. They helped me fix a wire feed problem on a cheapo Handler mig unit. They even suggested a cheaper alternative for parts. You may be able to get a manual from them too.
The Following User Says Thank You to slip knot For This Post:
Old 04-18-2015, 11:07:46 PM
Jeff
That is the guy. He has wiring diagrams and what ever you might need.
Jim
Old 05-10-2015, 10:22:38 PM
Jeff in PA's Avatar
One of the mods on the Hobart welding forum helped me out with a manual.
Thanks again everyone
Jeff
What do you know about this Hobart TIG welder ? cub102 Welding Shop 10 11-27-2013 08:34:57 PM
Hobart GR-303 Welder-Gen Help Jim Tremble Generators & Electric Motors General Discussion 7 01-27-2011 11:42:49 AM
Hobart Simplified Arc Welder manual John Hamilton Welding Shop 0 10-10-2006 01:49:25 PM
Old Hobart Welder DaveHath Welding Shop 7 01-10-2006 09:17:27 AM
DCC-353-P Hobart Welder Rob-n-LA Welding Shop 2 07-17-2004 03:55:11 PM
