Welding Shop
Linkwelder dc 225 starting problems
this thread has 2 replies and has been viewed 1127 times
Old 05-05-2015, 11:26:41 PM
gnarles gnarles is offline
Default Linkwelder dc 225 starting problems
Hello,
I have a problem with a dc-225/3-AS
code no.6630
ser. no. 641915
Onan ccka-s/1627g
Any way it uses 24 volts to spin engine over using the generator.
Problem is the solenoid seems to be sticking and wont stop spinning engine.
I have to pull cable off of the battery to get it to stop.
I have tryed other solenoids new and old and nothing seems to be working.
I have fried a couple of push button switches.
What do you guys think?This is a good old welder and I sure would rather be welding than beating my brain on this problem.
Any info would be greatly appreciated.
Old 05-06-2015, 01:21:11 AM
Default Re: Linkwelder dc 225 starting problems
are you replacing the solenoids with the correct Onan type? they are different than the similar looking Ford common type? wired differently inside.
Do you have the CCKA manual for trouble shooting?
If not come on over to the onan forum and someone will hook you up with the correct manuals.
Old 05-06-2015, 06:20:48 AM
Ed,
I didnt know that they where different than Ford ones.There wasnt any markings on outside of them to even hint at that.So this explains why everyone is stumped around here that has looked at it.
I dont have an onan manual,but I have the lincoln side of it.
I will post on onan forum.
Thanks for your quick reponse Ed!
IHC Titan 1HP, starting problems MSiv Hit & Miss Gas Engine Discussion 3 07-29-2014 06:34:26 AM
Starting problems. Jdman1930 Hit & Miss Gas Engine Discussion 7 05-15-2010 12:01:47 PM
Emerald Plus Starting Problems FOX8338 Onan Generators 4 12-24-2009 11:47:37 AM
Piston Removal 225 Linkwelder Dennis from Maine Onan Generators 1 11-11-2009 04:04:39 AM
Onan 2.5 AJ Starting problems WilsonsK Onan Generators 10 09-22-2008 04:58:08 PM
