Welding Shop
1980 bluestar2e
this thread has 0 replies and has been viewed 1160 times
Old 05-10-2015, 10:25:52 PM
Parrfam71 Parrfam71 is offline
Angry 1980 bluestar2e
I looked in parts manual above the resistor#28 there is a solid wire under a cloth sheath it had a small burn mark and sonethung burnt out itcsay part #30 a ww resistor 25 watt 3 ohm . But I got a dif style but same stats, if I welder eith it on I get a small arc or low power to grinder eith it off it runs normal but parts manual doesn't say what is missing .
1980 John Deere 317 bigGURN Garden Tractors and Mowers 6 09-30-2015 07:58:56 PM
Value of 1980 Onan OJC? KSU_cowboy Onan Generators 7 11-27-2005 11:25:00 AM
Value of 1980 Onan OJC? KSU_cowboy Onan Generators 0 11-27-2005 12:04:05 AM
1980's 4 cyl 12.5kw diesel genset Deng43 Kohler Generators 12 10-19-2005 03:43:51 AM
1980 Mercury 50hp carb ? Mercury Man Hit & Miss Gas Engine Discussion 1 05-17-2005 02:57:41 PM
