Welding Shop
Miller AEAD 200LE vacuum pump hose routing needed
this thread has 4 replies and has been viewed 2154 times
Old 05-26-2015, 10:15:10 AM
forestfarm forestfarm is offline
Default Miller AEAD 200LE vacuum pump hose routing needed
I just picked up a Miller AEAD 200LE for short money.The fuel tank was improperly connected to the carb and the fuel pump sat disconnected on the flywheel housing.Could someone please explain to me how it is supposed to be connected?I dont see any where to connect it to vacuum.The carb doesnt have an inlet at the base where you could connect a vacuum hose.I dont know where it was originally connected.I got the machine running in short order but need the fuel pump squared away so i can put the fuel tank back in its proper location.Thanks
Old 05-26-2015, 05:14:02 PM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Re: Miller AEAD 200LE vacuum pump hose routing needed
Vacuum line is on the "back" of the pump and goes through a hole in the shroud to a port on the block or timing cover.
Old 05-26-2015, 08:52:22 PM
StrikeForce StrikeForce is offline
**This is assuming your model is like mine and has the Onan engine**
The fuel pump isn't a vacuum style pump, its a pulse pump. You need to have a hose connected from the crank cover to the back of the fuel pump. This creates a pulsation from the crank case pressure. It is possible that the fuel pump became weak which is why it was disconnected. This happens over time. Also, what can happen is the check valve gets worn so you can loose the prime to the engine. In that case, you can run to NAPA and get a small electric fuel pump which works just as well. If you go that route, we can discuss that more later.
Old 05-27-2015, 01:04:01 AM
Thanks for the replys.I didn't remove the pump.Thats why I didn't know there was a port on the back.I will run the machine and see if the pump is actually pulling a vacuum on one of the two ports.One cas a cap on it.Thanks.If I cant bring it back to life I will buy a generic briggs vacuum fuel pump.Thanks
Old 05-27-2015, 11:19:28 AM
I stand corrected.I will reconnect the pulse pump fuel lines to see if it will pump before I carefully open it up to take a peek.Thank you for your information.
miller aead 200le marvgarr Welding Shop 2 08-23-2013 01:47:58 PM
Need Help with Miller AEAD-200LE Onan Engine hotrog Onan Generators 15 08-21-2013 02:04:56 PM
TIG set up for my Miller AEAD 200LE? cweaver7018 Welding Shop 2 11-13-2010 10:22:45 PM
Miller Blue star 2E OR AEAD 200LE bobgil Welding Shop 3 05-12-2010 09:31:48 PM
Miller AEAD-200LE: Engine options ASavage Onan Generators 6 11-15-2006 12:05:41 AM
