Smokstak Down Under
What Parts Do You Need?
this thread has 207 replies and has been viewed 26792 times
Old 06-27-2015, 02:35:06 AM
john gilbert john gilbert is offline
Default Re: What parts do you need?
Hi Michaely of Orange ,I may be able to help you out with the screen cooler for the Bartram, I will email you Cheers John
Old 06-27-2015, 02:40:42 AM
lewman lewman is offline
Email NOT Working
Hi out there
I am still looking for a Madison kipp 3 port oiler and a transporter for a 6hp mogul also a accurate o magneto and trip finger
Thank lewman
Old 06-27-2015, 04:51:37 AM
Michaely Michaely is offline
Thanks John,
I'll be in touch
M
Old 06-27-2015, 07:26:16 AM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
I am looking for three small matching wine glass oilers with 14x1.50 threads. Need to be in good condition, thanks Gene Fisher
Old 06-27-2015, 08:48:33 AM
Russell Meadows Russell Meadows is offline
Hello, Im looking for Alamo 5hp Blueline head
Root and Vandervoort 2hp head
Mogul 6hp flywheel
Waterloo boy 6hp flywheel
Tangye 7hp Vaporisor
Thanks Russell
Old 06-28-2015, 03:55:07 AM
Luke Luke is offline
I need a exhaust push rod for a vertical 4HP YB Stover, inc trip for webster mag if possible, a piston for 1 1/2HP Type A Olds engine and a crank handle for a 3HP vertical Australian Hornsby / Triumph engine. Cheers Luke
Old 06-28-2015, 05:14:49 AM
Rob.S Rob.S is offline
Hi Luke
what size crank shaft is the crank handle
rob.s
Old 06-28-2015, 08:59:40 AM
Brock Summerfield Brock Summerfield is offline
Email NOT Working
G,day
I am looking for a flywheel For a nelson bros type p also flywheels for 1.5hp Stover pipe domestic , a mate of mine is looking for a ignitor for a vertical famous
Brock
Old 06-28-2015, 05:36:03 PM
Neil Mactavish Neil Mactavish is offline
Hi every body i am chasing a trip finger for a poldelsak webster . For a horizontal famous ......... Cheers neil
The Following User Says Thank You to Neil Mactavish For This Post:
  #30
Old 06-28-2015, 09:28:28 PM
mightgo mightgo is offline
Hi all. I could do with a dash pot (damper) set up for a 4 hp Buzacott.Horizontal.... Regards Brian.
Old 06-29-2015, 05:53:29 AM
Originally Posted by Rob.S View Post
Hi Luke
rob.s
Hi Rob, thanks for the reply. I did not get to the shed tonight so I'll measure it and get back to you. The crank has a pin through it protruding on each side for the crank to grip when turning.
Cheers
Luke
Old 07-13-2015, 04:29:30 AM
Famous Fitter Famous Fitter is offline
Hi all,
I am looking for parts (or parts engine) for a 1918 low tension 1.5hp "EMU" (Hercules) that i am restoring for my son
what we have is quite good but need the following parts :
-Flywheel (left and right appear the same)
-Webster magneto and Igniter (any condition )
any help with these parts would be apreciated- thanks
Old 07-13-2015, 05:43:19 AM
JimDoyle JimDoyle is offline
Hi All
I am looking for a magneto cam gear cover for a 1914/15 Fuller Johnsen farm pump engine.
Cheers
Jim
Old 07-13-2015, 07:48:26 AM
rusty gold rusty gold is offline
hi all i need a few parts mostly for common engines
hopper for 3 hp buzzacott vertical
magneto bracket either but prefer rotary for 2 hp horizontal rosebery
carb parts for the wittry mixer off a 4 hp waterloo boy
lister coffee pot hopper for an a type
big end bearings,cam gear bracket [cast alloy] for a fairbanks morse z 2hp
big end bearings for 3 hp cooper tc horizontal
i think thats it for now but there will prob be more will have a look around this week
---------- Post added at 09:48 PM ---------- Previous post was at 09:45 PM ----------
hi all i also need a crankhandle for a bartram ak
cheers
Old 08-04-2015, 11:03:39 PM
freshieslures freshieslures is offline
G'day all,
Clutterbuck 6 1/2 hp parts needed.
Side shaft skew gear 5 inch dia 32 teeth. (blackstone are different have 24 teeth)
Top air valve rocker, picture or drawing.
Big end bearing dia 2 3/4 x 2 1/2 wide. I have an austral one i can swap (dia 2 1/2)
Thanks Justin
Old 08-05-2015, 06:57:30 PM
piciron piciron is offline
Hi looking for a mag for a john deere 1 1/2 e or just housing thank you Don
Old 08-20-2015, 08:47:19 AM
julieisherenow julieisherenow is offline
Although not a part I am after a service manual for an inline 6-71 Detroit Diesel. I have it in a 1978 Atkinson which we are about to take to Alice Springs to the Hall Of Transport reunion.
Thank you
Old 08-23-2015, 07:02:45 AM
R Allen R Allen is offline
What about tractors I need a good flywheel for a R model Lanz Bulldog left hand side with the ring gear for starter motor. Robert Allen
Old 10-21-2015, 09:36:44 AM
Thanks to engine1, for supplying a fuel pump for my clutterbuck.
Now looking for a water pump for a 6 1/2 hp star, also interested in any other star parts you may come across.
cheers Justin
Old 10-21-2015, 07:29:20 PM
Adam Jones Adam Jones is offline
Hi guys I'm looking for a left hand flywheel for my Hercules 6hp. The left hand one has the timing marks on it.
Thanks Adam
12-20 Twin City Cylinder Head Parts interchangeable to new available parts. jesters13 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-31-2017 11:37:59 PM
Clinton Master Parts Price list (1964) & parts cross-reference TractorDom Small Air Cooled Gasoline Engines 0 11-26-2015 11:02:54 PM
Digitize 3D Parts, Broken parts, etc. Great video shown at Jay Leno's Garage Dusty Hit & Miss Gas Engine Discussion 0 04-10-2013 11:19:56 AM
Looking for Goold shapley and muir 3 1/2HP parts and to contact others needing parts Nathan K. Hit & Miss Gas Engine Discussion 8 03-16-2013 11:52:47 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
