Welding Shop
Fairbanks Morse X4B16A-1 magneto cross fires
this thread has 2 replies and has been viewed 1570 times
Old 07-20-2015, 04:46:39 PM
blacktinlizzie blacktinlizzie is offline
Question Fairbanks Morse X4B16A-1 magneto cross fires
I have a Lincoln SA200-F163 welder that just stopper running I replaced Cap rotor points and related parts on the FM X4B16A-1 magneto and had good spark but it will fire on the same terminal three of four snaps. I looked for carbon tracking or cracks or anything even replaced cap and still the same.
What am I missing
Thank you
Old 07-25-2015, 02:01:31 PM
dkamp dkamp is offline
eMail NOT Working
Default Re: Fairbanks Morse X4B16A-1 magneto cross fires
Sounds like very high voltage....If you have resistor type plugs, or resistance wires, or both, remove them, and install non-resistance plugs and solid core wires. resistance wires force voltage very, very high, eventually exceeding the insulation capacity of the magneto's cavity AND coil windings.
Also- many of these magnetos have a gear under the rotor- the armature turns the rotor gear to position rotor towards proper plug. Well, one of those gears is a fiber sandwich, and if the rotor snags on some debris, will jam and strip that gear, leaving it pointed in just one direction.
Old 07-26-2015, 05:37:31 AM
Thank you for the reply.
If I bench test the magneto with a solid core copper plug wire I get a spark at the post that the rotor is pointing to and a weaker spark at the posts before and after it. I have replaced the cap and rotor and cleaned everything still the same.
Fairbanks Morse FMJ magneto help oldschoolwisconsin Small Air Cooled Gasoline Engines 6 05-25-2016 11:59:57 AM
fairbanks jumps when fires ... matt86 Hit & Miss Gas Engine Discussion 17 04-06-2014 08:05:00 PM
Fairbanks Morse 6hp finally fires Chris Steffen Hit & Miss Gas Engine Discussion 4 11-27-2009 07:26:03 PM
Fairbanks-Morse Magneto Mike Schweikert Hit & Miss Gas Engine Discussion 1 08-11-2007 03:59:27 PM
Fairbanks-morse magneto farmerjoe Antique Engine Archives 0 11-14-1999 11:58:34 AM
