Welding Shop
Shingle Mill Cam Slot repair
this thread has 2 replies and has been viewed 1086 times
Old 01-04-2016, 10:55:23 AM
JD840 JD840 is offline
Default Shingle Mill Cam Slot repair
Hello. Im looking for a shop that can repair this cam slot. The gear is 32 inches across and 2 inch wide. The cam slot is worn as pictured. I live in MN but would put on a pallet and ship if needed.
Name:	.shingle mill gear (1).JPG
ID:	242964   Click image for larger version
Name:	.shingle mill gear 2.JPG
ID:	242965   Click image for larger version
Name:	.shingle mill gear (3).JPG
Old 01-05-2016, 04:47:19 PM
Langes Machine Shop Langes Machine Shop is offline
Default Re: Shingle Mill Cam Slot repair
I sure would take a look at it if you would want to bring to Hector. My phone number is 320-848-2132.
The Following 2 Users Say Thank You to Langes Machine Shop For This Post:
Old 01-06-2016, 01:37:18 PM
OTTO-Sawyer's Avatar
If it was mine I'd probably profile out a piece of steel and pin it in place, but I'm sure Langes Machine Shop can fill it with bronze and cut it to shape and last just as long if not longer than a steel insert patch job.
From what I've seen in other threads, he does pretty damn good work and stands behind it.
I doubt you'd get a better repair anywhere else.
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
Shingle Mill value? Dale S Farm Antiques and Collectibles 40 05-09-2015 09:49:58 AM
Shingle Mill cobscooklumber Farm Antiques and Collectibles 3 04-30-2011 10:39:42 AM
Shingle Mill help OldAgIron Farm Antiques and Collectibles 12 08-09-2009 10:09:22 PM
Shingle Mill TABest55 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 03-15-2008 08:56:51 PM
Shingle Mill ID Doug Kimball Hit & Miss Gas Engine Discussion 1 03-10-2008 01:54:31 PM
