Welding Shop
Cleaning Brazing Flux
this thread has 8 replies and has been viewed 1364 times
Old 02-15-2016, 02:39:48 PM
Holland501 Holland501 is offline
Default Cleaning Brazing Flux
I was wondering if anybody could suggest a flux that is easy to remove. Sometimes brazing is the best means of joining/repairing something rather than welding. However trying to remove the flux can sometimes be almost impossible. Most recommend soaking the object in very hot water for a period of time. Most of the time that isn't a practical option. Any ideas would be appreciated. Thanks
Old 02-15-2016, 02:42:30 PM
Default Re: Cleaning Brazing Flux
Simple borax. My nephew swears by it for his blacksmithing.
Doc
Old 02-15-2016, 05:46:35 PM
I've got some 20 Mule Team Borax. I'll give that a try and see how difficult it is to remove the glassy flux after it cools.
Thanks for the suggestion.
Old 02-15-2016, 07:29:42 PM
I have a few coated rods left but my next purchase will be bare rod if I can come up with a flux that is easy to remove when the job is finished.
Old 02-15-2016, 07:36:38 PM
I use bare rod and a blue multi purpose powder flux. its pretty hard to get off.
The Following User Says Thank You to slip knot For This Post:
Old 02-15-2016, 07:53:25 PM
Bead or sand blasting removes it, don't know if it would be practical in your case.
Old 02-16-2016, 08:35:59 AM
dependable dependable is offline
Harris Stay-Silv flux with their Dynaflow bare brazing rod does a neater job than the pre fluxed rod I have. Have not noticed much flux residue, but if there, have not tried to remove it.
The Following User Says Thank You to dependable For This Post:
Old 02-16-2016, 10:34:10 AM
Only thing I've found that works is scraping it off - helps to have water to help dissolve it some while scraping.
The Following User Says Thank You to beezerbill For This Post:
Old 02-17-2016, 01:03:01 PM
I'd like to thank everybody once again for offering their suggestions. I did try the plain Borax. It seemed to work fine as a flux but was just as hard to remove as the flux coating already on the rods.
I actually tried using bare rod on 'freshly cleaned' steel. It wetted the same as with flux but with nothing to clean afterwards. Since anything I braze isn't of a critical nature, I'll probably use that method in the future.
Thanks again.
White Stay-Silv flux any use in brazing cast iron? sdowney717 Welding Shop 6 12-29-2015 06:22:55 PM
The white flux coated brazing rod composition, bronze or brass? sdowney717 Welding Shop 4 12-07-2013 03:06:47 AM
MORE Brazing help PLEASE!!! 11echo Welding Shop 12 12-07-2013 02:58:34 AM
Brazing vs Welding Mike G Welding Shop 5 02-27-2013 11:23:01 PM
Welding or brazing terry tabb Hit & Miss Gas Engine Discussion 7 11-07-2008 10:03:33 PM
