Welding Shop
Hercules IXB5 Water Pump
this thread has 7 replies and has been viewed 2070 times
Old 03-12-2016, 03:02:14 PM
lynnlpitts lynnlpitts is offline
Default Hercules IXB5 Water Pump
Does anyone know where to send my Hercules IXB water pump assembly off to rebuild? I have it partially apart and am not familiar with the packing material that is broken...appears to be a ring of carbon that is held against the brass shaft bushing with a spring and cup. I have the manual but it is not too detailed or list part numbers. Thanks, Lynn
Old 03-12-2016, 09:16:01 PM
51cub 51cub is offline
Default Re: Hercules IXB5 water Pump
Okay, I'm going to have to be the guy that exposes himself here. Why can't you substitute it with something more easier to get hold of?
Old 03-13-2016, 08:40:02 AM
I would like too...but I don't have that knowledge about packing materials...anyone know of rebuilders that they could recommend?
Old 03-14-2016, 09:05:27 AM
If you can get the packing out then go to http://www.mcmaster.com/# and see if they have something to match.
Old 03-14-2016, 10:25:44 AM
Gene Williams Gene Williams is offline
Default Re: Hercules IXB5 Water Pump
I sent a water pump off a Gibson tractor in for a rebuild through NAPA. This was quite a few years ago but maybe they still offer the service.
The Following User Says Thank You to Gene Williams For This Post:
Old 03-14-2016, 09:38:58 PM
I think it s for an IXB 3, which is a front fan belt driven pump...this one is a side shaft that also drives the mag....Thanks for the report!
Old 04-01-2016, 11:46:10 PM
coyote62ny coyote62ny is offline
i sent a water pump to a place in texas a few years ago to get it rebuilt but cant remember the name of the place
Old 04-02-2016, 05:55:24 PM
I just finished rebuilding the pump...got parts from Jerry at Hercano (nice people) had to machine the shaft down a few thousands and brazed and turned back to .750. Shaft has a tight spot in pump but I think it will lap in...haven't put in back in yet...trying to figure the BTC timing...The Manual leaves a lot to be desired. Hope it doesn't leak to bad! Sure beats watching TV!
Need help with special hercules water pump... Kentuckydiesel Multi-Cylinder Stationary Gasoline Engines and Power Units 6 10-03-2015 09:43:41 AM
Hercules engine and Hercules water pump.. Fred Van Hook Hit & Miss Gas Engine Discussion 0 06-30-2014 05:43:00 PM
Hercules ZXB water pump Mike Schweikert Multi-Cylinder Stationary Gasoline Engines and Power Units 4 09-12-2012 08:19:30 AM
Hercules IXB5 Generator Set Zorch Multi-Cylinder Stationary Gasoline Engines and Power Units 13 03-14-2012 12:28:28 PM
1951 hercules water pump cjs10 Generators & Electric Motors General Discussion 0 10-02-2004 11:57:24 AM
