Welding Shop
Welding SS with acetylene torch
this thread has 6 replies and has been viewed 1671 times
Old 04-05-2016, 04:54:13 PM
Default Welding SS with acetylene torch
I want to learn how to do this.
There is a flux called Solar flux B, high temp which people on some welding forums say works to shield the metal.
It is 45$ per pound. the website says it is used on the backside of the weld in lieu of purging with a shielding gas.
I was wondering about welding and having this also on the front side with a longer neutral flame.
Anyone have experience with welding SS, looking to do NPT pipe 304 or 316 welding of a 2.5 inch diameter.
Not a lot of welding, maybe but weld 4 short sections of pipes.
I doubt I would weld tubing, but I might.
The weld has to withstand engine exhaust heat, so is silver brazing not appropriate?
I can braze - weld steel, bronze, cast iron ok with my torch.
I dont want to spend money buying a mig or tig setup. And I like doing my own work.
---------- Post added at 04:54:13 PM ---------- Previous post was at 04:40:26 PM ----------
http://www.hobartwelders.com/weldtal...p/t-36086.html
Ok, I just found this and was reported to be successful.
https://www.tinmantech.com/products/...g-supplies.php
Stainless Steel Gas Welding Flux
For Oxy-acetylene welding on 310, 303, 304, 316, 321, and 347 alloys, using 308 and 309 fillers. Mix with isopropyl alcohol, coat both sides of the sheet, and the filler, use a neutral flame. - Premium Quality, 4 oz. jar.
Old 04-05-2016, 05:39:12 PM
Default Re: Welding SS with acetylene torch
just get some stick electrodes and stick it.
The Following User Says Thank You to Ed Radtke For This Post:
Old 04-05-2016, 05:47:24 PM
I have only an AC welder. I have read you need DC?
Maybe not!
found this mention, AC can be used. I suppose I need to call and find out what I could use.
It would be nice to stick weld SS
http://www.lincolnelectric.com/en-us...lectrodes.aspx
Old 04-05-2016, 09:07:29 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
I have got plenty of ss electrodes and I use them all they time with AC buzz box welders.
This is taken from mc master carr:
Type 309 (E309L) can also be used for other stainless steel where pre- and post-heat treatment aren’t possible as well as for joining dissimilar metals.
Type 316 (E316L) are often used on food-processing equipment. They also make welds on molybdenum-bearing steels.
It works really well and lays down very nice in my experence
The Following 2 Users Say Thank You to ehpower2 For This Post:
Old 04-06-2016, 07:58:26 PM
Glad to hear that.
I called AirGas and they have the 308-16 rods.
E308-16, -17 will work with AC.
They are about $6 something per pound, and you can buy minimum of 3 pounds.
This actually helps me a lot.
I might also wish to weld some 304 SS sheet, has a thickness of .060.
Do you think 3/32 or the smaller rod? How many amps?
Could these rods be used to fill in crevice corroded holes in the sheet?
The SS is a trim tabs for boats.
Old 04-06-2016, 08:31:08 PM
Rasper Rasper is offline
I have gas welded a fair amount of stainless in my sculpture work. I use a flux sold by a master metal worker who fabricates automobile bodies and airplanes.
http://www.tinmantech.com/products/w...g-supplies.php
He also sells a booklet on technique that I found to be extremely helpful.
http://www.tinmantech.com/html/stainless_booklet.php
It requires a somewhat different technique than welding steel or aluminum. With stainless you use a smaller flame than with steel because stainless conducts heat poorly. You also don't wave the flame; you keep it on the puddle and move it straight forward so the puddle is in the flame at all times.
As with any new skill it takes a little practice, but it is not difficult to do.
Richard
The Following User Says Thank You to Rasper For This Post:
Old 04-07-2016, 09:22:11 AM
And I forgot to say that you must keep the filler rod in the flame all of the time—no dabbing. The flame prevents oxidation.
Richard
oxy-acetylene torch troubles, burning in mixer, popping sdowney717 Welding Shop 23 04-27-2014 12:10:41 PM
Propane tip for old oxy/acetylene cutting torch PTSideshow Welding Shop 9 06-26-2011 02:55:49 PM
Need help with acetylene torch Ronald E. McClellan Welding Shop 9 03-16-2007 09:13:17 PM
Spray welding torch info wanted Gasengin Welding Shop 5 02-24-2006 10:43:16 PM
