Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
1-71 Detroit Diesel (GM)
this thread has 282 replies and has been viewed 36906 times
Old 09-01-2017, 09:56:55 AM
K-Tron K-Tron is offline
Default Re: 1-71 Detroit Diesel (GM)
I inquired on that as well. It is possible that he might have a marine 1-71. I have next to no images, or information on them. I have seen 1-71RA, 1-71RC, 1-71P, 1-71G, but never a 1005. Even the serial number is off. Usually it is A-XXX, not 1-XXX. I cant wait to see more pictures of the engines he has. 171-125 came out of New York and now resides in Colorado, the brother of Mbetti's #124.
Chris
Old 09-01-2017, 11:31:52 AM
The Diesel Doctor The Diesel Doctor is offline
Default 1-71 Detroit Diesel (GM)
The only picture i have seen of a 1-71 marine engine. It has a mechanical Twin Disc reverse and reduction gear. The 6-71 in the Navy LCVP used this gear box. AL[ATTACH]Click image for larger version
The Following User Says Thank You to The Diesel Doctor For This Post:
  #183
Old 09-01-2017, 11:40:51 PM
AngrySailor AngrySailor is online now
The size of that gearbox on that little 1-71
Reminded me of working at a performance shop years ago, we had an open house and one of our customers brought his roots blown mazda RX-7 rotary. The blower was as large as the engine, people were legitimately asking which powered which as it was so obscene
Old 10-15-2017, 05:27:42 PM
The most challenging part of my restoration has been the radiator The art of repairing radiators is in the past. Going to Honolulu tomorrow to check out a shop that was founded in the 40sClick image for larger version
  #185
Old 10-15-2017, 06:07:47 PM
C'mon... Tell me the name on that radiator shop is a joke.
  #186
Old 10-15-2017, 06:31:51 PM
For real, 77 year old family business passed down to the son`s. Hoping grandpa passed down his talents also.
Old 10-29-2017, 07:09:13 PM
Found a vintage fish cart at a estate sale. The tag said it came from Wilmington CA. On the side it is stamped M.S.Co. Does anyone have info on this? I have been looking for some steel wheels I can now build a cart for my little one lunger.Click image for larger version
  #188
Old 11-03-2017, 12:53:54 AM
Getting the fresh water pump operational. I machined a 2-71 seal and impeller assy to the measurements and angles on the 1-71 one. Spray welded the shaft to clean up the sealing surfaces. Also machined the cast boss in the pump housing to accept a stainless steel insert which i made. The carbon seal will ride on the insert and should seal in the coolant. (i hope) ALClick image for larger version
The Following 3 Users Say Thank You to The Diesel Doctor For This Post:
  #189
Old 11-03-2017, 02:30:38 PM
kwfiggatt kwfiggatt is offline
Did you do the shaft spray welding yourself or have a shop do it? Does it use an oxy-fuel torch and a wire feeder? I'm curious about the process as I've never really seen it done but have read about it a bit.
Thanks,
Kevin
Old 11-03-2017, 09:22:13 PM
Kevin, I had it done in a shop in Honolulu. I also have not seen it done. The advantages are you don`t have to compromise the tensile strength of the metal with excessive heat. That`s important on something like a propeller shaft that transmits load.
  #191
Old 11-04-2017, 01:02:35 PM
Larry Evans's Avatar
Larry Evans Larry Evans is offline
In the 1950's I used to operate a small freight boat from San Pedro to a camp on Catalina Island and one of the marine hardware suppliers was the Manhattan Supply Co. They might have been the source for your cart.
The boat I operated was powered by a Detroit 4-71.
Larry
Larry Evans
http://www.oldengine.org/members/levans/
The Following 2 Users Say Thank You to Larry Evans For This Post:
  #192
Old 11-19-2017, 09:30:48 PM
Mbetti Mbetti is offline
Gauge layouts I have.
ID:	296501   Click image for larger version
The Following 3 Users Say Thank You to Mbetti For This Post:
  #193
Old 11-22-2017, 12:56:07 AM
My radiator restoration is not going well. I was quoted 2K to restore it. The out side dimensions including the top and bottom tanks are 12" wide and 18" tall with a fill in the top center. Inlet and outlet are on the back of each tank. There must be a similar size radiator out there used in a piece of equipment. Welding machine, Small tractor, Generator. AL
Old 11-22-2017, 06:40:14 PM
Do you need that built in oil cooler in the bottom tank?
Old 11-22-2017, 08:01:53 PM
No i don`t. It is the engine oil cooler and i could hide an external cooler in the bottom of the radiator shell. I also found on line a aluminum radiator used on a ATV of approximately the right size that i could modify to fit.
Old 11-25-2017, 09:32:27 PM
Mbetti, My 1-71 Click image for larger version
ID:	296934cam rocker rollers had needle bearings in them. Didn`t feel good when i turned them. Replaced them with cam follower pin and bushing kits P/N 892814 which are used in 53, 71 and 92 engines.
  #197
Old 12-08-2017, 12:09:47 AM
Just did some in frame repairs ( in the boat) on a 6-71TI in Honolulu. Check out the name plate specs. 485 HP at 2500 RPM and a no load speed at 2700. It is using 145MM injectors. Talk about some screaming jimmys.Click image for larger version
The Following 8 Users Say Thank You to The Diesel Doctor For This Post:
  #198
Old 12-08-2017, 11:24:03 PM
Here is something you don`t see every day. The 1-71 engine oil cooler located in the bottom tank of the radiator. Have given up on trying to get the radiator repaired over here. I cut the core out and am ordering a new one from the mainland. I feel confident i can do the job myself. ALClick image for larger version
The Following 5 Users Say Thank You to The Diesel Doctor For This Post:
  #199
Old 12-15-2017, 12:43:46 AM
Got an early Christmas present. Its a one cylinder Yanmar marine diesel generator set. A friend salvaged it from a large sailboat that went up on the reef in the 70s. It didn`t get wet and had it stored in his garage all this time. It is not stuck. Wife says i can`t start on this project until i get the 1-71 running. ALClick image for larger version
  #200
Old 12-15-2017, 09:02:03 PM
I brought my radiator to a local mom pop shop that has been around forever. My core is ok but I asked him what it would cost to recore and he said probably $3-400.
The Following User Says Thank You to Mbetti For This Post:
1-71 Detroit Diesel (GM) The Diesel Doctor Vintage Diesel and Oil Stationary Engines 3 05-21-2016 05:30:26 PM
Detroit Diesel 8-71T Oil in Air Box Tim in Mexico Vintage Diesel and Oil Stationary Engines 11 10-10-2015 08:19:25 PM
Detroit Diesel 671 DaytonEngines Vintage Diesel and Oil Stationary Engines 4 08-23-2014 08:49:06 PM
Detroit Diesel Elec Power DDC25U with Diesel Perkins Engine Manuals? MP5ForTheWin Generators & Electric Motors General Discussion 4 08-14-2012 12:34:30 AM
Gen. set wtd. Detroit Diesel Denny Foster Generators & Electric Motors General Discussion 0 11-13-2000 10:06:06 PM
