Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
1-71 Detroit Diesel (GM)
this thread has 282 replies and has been viewed 36922 times
Old 02-03-2018, 08:58:08 AM
Sooty Jim Sooty Jim is offline
Default Re: 1-71 Detroit Diesel (GM)
Practical Greasy Yoga... what fun!
The Following User Says Thank You to Sooty Jim For This Post:
Old 02-07-2018, 11:40:29 PM
The Diesel Doctor The Diesel Doctor is online now
Building up a 12V92TI marine engine from 3 parts engines. And yes there are a few parts in this engine that are original to my 1-71. Detroit Diesel interchangeability. ALClick image for larger version
The Following 2 Users Say Thank You to The Diesel Doctor For This Post:
  #223
Old 02-08-2018, 12:39:51 AM
Vanman Vanman is offline
What is the V angle on that? I recall the 12V71 is something odd like 62*. A two stroke, 60* V-12 with six throws on the crank always fires two cylinders at once. A 30* or 90* V angle would make for 12 evenly spaced power strokes. That would be electric - motor - smooth! And SWEET sounding!
Old 02-08-2018, 01:59:56 AM
I think the V angle of a 71 and 92 are the same. Will try and confirm. As every stroke is a power stroke on a two cycle in one revolution they fire very close to each other. Six rod journals and 12 rods. Typo on the 12-92 chart 1L on the second line should be 1R. AL Click image for larger version
Old 02-08-2018, 02:24:11 AM
Page two of the firing order chart has a lot going on in one turn of the crankshaft. AL Click image for larger version
The Following User Says Thank You to The Diesel Doctor For This Post:
  #226
Old 03-11-2018, 09:23:20 PM
Talking Re: 1-71 Detroit Diesel (GM)
Plugged air boxes and covers on a 12V 92 marine engine. It dosen`t get much worse than this, but it was still running. Hard to stop a jimmy. Beautiful day out here today.Click image for larger version
The Following 3 Users Say Thank You to The Diesel Doctor For This Post:
  #227
Old 03-11-2018, 09:54:30 PM
Yikes! What causes that? I would think that a marine engine would be working too hard most of the time for it to be caused by hours upon hours of idling.
Old 03-11-2018, 10:26:31 PM
tourist dinner cruise, Idle out idle in. They were also a bit lacking on their on the oil changes and maintenance. AL
Old 03-11-2018, 11:23:59 PM
Wow, that's sad. Poor Detroit.
Old 04-10-2018, 03:16:00 PM
Changing the crankshaft front oil seal on a 8V 92 TAB marine engine. !!NOT A EASY JOB!! Seal leaking after 23 years of service. To break loose the outer tapered cone which holds the damper hub in place required some heavy duty tools.Click image for larger version
  #231
Old 04-10-2018, 03:43:47 PM
Mbetti Mbetti is offline
Default Re: 1-71 detroit diesel (GM)
My genset 1-71 uses a limiting speed governor that has 2 positions, idle and no-load. I can actually vary the no-load by means of a cable that tensions the high speed spring to a small degree to fine tune to get the HZ cycles. The governor and rack setup are very much like modern 2 strokes.
As for the blower, mine has a nice flap which is just as precise as a gasoline carb has. It is controlled by linkage to a mechanical overspeed mechanism that trips it close. It can then be manually reset similar to later engines.
Old 04-10-2018, 04:03:09 PM
Bsessoms Bsessoms is offline
Lightbulb Re: 1-71 Detroit Diesel (GM)
I have an 1950's allis chalmers dozer, with a bad starter. Terrible to get to check
out. It has the 2-71 diesel eng. I would like to remove the old foot push button
starter selenoid and have possibly an external selenoid like the ford setup?
Is this possible? I don't know if it has a mechanical arm to force the starter
gear into flywheel or not? Any one tried this Before? Thanks B.
Old 04-10-2018, 05:33:39 PM
It depends on how many amps the starter takes. For a diesel, it may draw too much for the Ford solenoid to take. As for the starter itself - you need to see how the flywheel drive is actuated. Some depend strictly on starter armature torque, as the starter spins up - not exactly a Bendix drive.
Some have a pole show that is attracted by the field coil (as in the Ford type), and a completely separate solenoid that completes the starter motor power circuit. Others use the Delco-Remy type - an external solenoid, mounted to the starter itself, that combines the activation of the starter motor circuit, but also thrusts the Bendix drive into the flywheel. These can be activated by a simple momentary switch on the dash or by an ignition switch with a start position. The Ford and Delco systems are different! Ford uses a grounded circuit to activate the solenoid, GM (Delco) uses battery positive to activate.
Old 04-17-2018, 12:42:44 AM
Limiting speed governor control ---- I believe you have the same gov. that i have. It has three positions on the cover, shut down,idle and run. When you turn the control knob to increase the RPM it puts pressure on a plunger which makes contact with the idle speed adjustment needle. The more pressure on the idle spring and plunger go to the low speed weights and will give you more RPM. Hence the term HIGH IDLE. This part of the limiting speed gov works as a variable speed gov. The high speed weights and spring controls the no load RPM. When you run the generator at 1200 RPM it should be controlled by the low speed weights only. ( High idle) What timing pin did you use for the injector? ALOHA AL
Old 04-17-2018, 12:48:05 AM
My limiting speed governorClick image for larger version
Old 04-17-2018, 09:25:28 AM
ronm ronm is offline
If it is just a push button on top of the starter, my TD6 IH dozer has been converted to a Ford solenoid. A previous owner drilled & tapped a hole in the big copper contact & attached a cable to the solenoid. A push button on the dash, & it works fine.
Smokstak member #442
Old 04-18-2018, 09:28:38 PM
DETROIT 12V 92TI HAD to change out a piston liner kit. Marine engines can be stuffed in some pretty tight places. I told the owner that a Sawzall would make the job go faster. He didn`t go for it. Got the job done Just made more $$$. ALClick image for larger version
  #238
Old 04-19-2018, 04:34:48 PM
kwfiggatt kwfiggatt is offline
Wow - that looks awful. Was there any other access to the engine - ie. did an enclosure get removed so that you could access the engine? If not, you're both a contortionist and a magician... 8-)
Old 04-19-2018, 10:05:17 PM
There was a craw space between the engines so access to the lower end was possible. The 92 has four heads. the bad piston was #2 left bank. The cast iron oil pan weighs about 100 pounds. There is a small access plate on the bottom of that pan that i was able to reach through to unbolt the connecting rod from that journal. Believe it or not i have seen worse. AL
Old 04-20-2018, 09:36:19 AM
I hope you get paid well for that, makes me hurt just to think about it...
1-71 Detroit Diesel (GM) The Diesel Doctor Vintage Diesel and Oil Stationary Engines 3 05-21-2016 05:30:26 PM
Detroit Diesel 8-71T Oil in Air Box Tim in Mexico Vintage Diesel and Oil Stationary Engines 11 10-10-2015 08:19:25 PM
Detroit Diesel 671 DaytonEngines Vintage Diesel and Oil Stationary Engines 4 08-23-2014 08:49:06 PM
Detroit Diesel Elec Power DDC25U with Diesel Perkins Engine Manuals? MP5ForTheWin Generators & Electric Motors General Discussion 4 08-14-2012 12:34:30 AM
Gen. set wtd. Detroit Diesel Denny Foster Generators & Electric Motors General Discussion 0 11-13-2000 10:06:06 PM
