Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
1-71 Detroit Diesel (GM)
this thread has 282 replies and has been viewed 36916 times
Old 09-08-2019, 07:02:23 PM
The Diesel Doctor The Diesel Doctor is offline
Default Re: 1-71 Detroit Diesel (GM)
Found a pair of 6V92 TIAB DDEC marine engines that produce 104 HP per cylinder. They are set up with a intercooler and aftercooler both of which are fresh water cooled. They also have electronic fuel injectors and a bypass blower. Need a replacement turbocharger Detroit part# (23518263) or (23521195). ALClick image for larger version
The Following 2 Users Say Thank You to The Diesel Doctor For This Post:
Old 09-08-2019, 08:18:16 PM
Vanman Vanman is offline
Wow, that's really something. Would think they would just use an 8V92... Foreign object get in there?
Am getting ready to start work on the 671TA for my bus, and will be looking into improving on the paltry 270 hp it's currently rated at.
How's that 171 coming along?
Keith
Old 09-08-2019, 09:39:52 PM
They were a special build for Hatteras. Less weight and fit in the engine room better. The turbo failure cause is bit of a mystery. When the new owner took delivery he inherited the problem. Usually caused by a piece of the engine coming out of the exhaust port. Valve or a piece of the piston. All the cylinders are firing and it seems they don`t have pieces missing. Don`t have any history of prior failures or work. The 1-71 is still on the back shelf. I retired 12 years ago but still cant say no to some of my old customers and sometimes a new one. AL
1-71 Detroit Diesel (GM) The Diesel Doctor Vintage Diesel and Oil Stationary Engines 3 05-21-2016 05:30:26 PM
Detroit Diesel 8-71T Oil in Air Box Tim in Mexico Vintage Diesel and Oil Stationary Engines 11 10-10-2015 08:19:25 PM
Detroit Diesel 671 DaytonEngines Vintage Diesel and Oil Stationary Engines 4 08-23-2014 08:49:06 PM
Detroit Diesel Elec Power DDC25U with Diesel Perkins Engine Manuals? MP5ForTheWin Generators & Electric Motors General Discussion 4 08-14-2012 12:34:30 AM
Gen. set wtd. Detroit Diesel Denny Foster Generators & Electric Motors General Discussion 0 11-13-2000 10:06:06 PM
