12-20 Twin City Cylinder Head Parts interchangeable to new available parts.
this thread has 3 replies and has been viewed 941 times
Old 05-29-2017, 08:57:08 PM
jesters13 jesters13 is offline
Default 12-20 Twin City Cylinder Head Parts interchangeable to new available parts.
I'm rebuilding a couple 12-20 TC and my machine shop dosent want to spend alot of time trying to find valves that will work in these old heads.. so does anyone know what valves and guides I can use that are still available new?. I've heard farmall MD valves could work or possibly case LA valves.
I'm also bouncing the idea around in my head to put modern main bearing into it as well.. seems pouring babbit is a lost art that no one wants to deal with.
Old 05-29-2017, 11:21:47 PM
Alan Svanes Alan Svanes is offline
Default Re: 12-20 Twin City Cylinder Head Parts interchangeable to new available parts.
H & J Machine in Carrington ND will be able to help you out with any valves you may need. Henry has a lot of guides not sure if he has them for the TC 12-20. They are a sponsor here on smokstak.
701-652-3289
The Following User Says Thank You to Alan Svanes For This Post:
Old 05-30-2017, 11:31:26 AM
There are also sponsors with machine shops that pour babbitt on a regular basis as well!
Old 05-31-2017, 11:37:59 PM
I need to take a look and find someone close to PA... I also have a 20-35 that needs babbitt poured also.. that block is huge.
---------- Post added at 11:34:00 PM ---------- Previous post was at 11:32:58 PM ----------
I'll give them a call thanks!!!
---------- Post added at 11:37:59 PM ---------- Previous post was at 11:34:00 PM ----------
I'll give them a call.. thank you...
KTA MM Twin City Engine Parts a jossund Antique Farm Tractors 1 03-21-2016 11:13:22 AM
twin city 27-44 parts d21smith Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 03-30-2013 09:39:34 PM
Twin City Parts Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 02-06-2012 12:48:17 AM
Twin City Parts Wanted Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-12-2011 12:07:21 AM
Need engine parts for Twin City 20-35 Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 02-07-2006 01:33:06 PM
