Smokstak Down Under
Kelly & Lewis specs
this thread has 7 replies and has been viewed 1259 times
Old 08-16-2017, 12:55:20 AM
Eric Schulz's Avatar
Eric Schulz Eric Schulz is offline
Default Kelly & Lewis specs
Putting together a list of engines built by Kelly & Lewis is not easy. I have factory literature on some of these engines, which is full of technical details, but the bore and stroke and hp are mostly not quoted. This wasn’t only a problem with KL either. Any help with providing bore, stroke and hp for any of these much appreciated. It will later on be published, so guesses are not good enough.
30 - 3 and 4 hp
3AO - 2.5 and 6 hp
HI
HJA
HK
HL
HR
Mk IV
MVA
VEA
VEB
VEC
VFA
VFB
Eric
Old 08-16-2017, 09:15:29 PM
rodmart2008 rodmart2008 is offline
Default Re: Kelly & Lewis specs
was there just a H model as well??
Old 08-16-2017, 09:49:09 PM
The H was a 2hp, hopper cooled petrol engine with an open governor. This was followed by the HT, which I believe is the one with the enclosed governor.
The HI is the 2 stroke, crude oil engine.
Eric
Old 11-05-2018, 06:59:17 PM
It is now a long time since I started this thread. Unfortunately no answers to my questions. KL specs are really hard to find.
Eric
Old 11-14-2018, 11:06:24 PM
rodneyt rodneyt is offline
so where does this one fit in the list? no specs, i was just passing thru a couple years ago.
only got these 2 pics.
ID:	322915   Click image for larger version
Old 11-15-2018, 03:42:17 AM
The HI was made between 1939 and 1943. The one in the photo was made in 1940.
Almost all of these engines, including this one, were sold to the Grain Elevators Board, and used to power silos. They were commonly called silo engines because of this. I don’t think any went to WA.
At first glance the nameplate reads H7. The I is on a bit of an angle, and the horizontal line is just a scratch.
In 1949, a batch of HIA engines were made and mostly shipped to Bombay. No technical details. I suspect a slightly modified HI.
Eric
The Following User Says Thank You to Eric Schulz For This Post:
Old 09-04-2019, 09:26:00 PM
harrone harrone is offline
You don't seem to have the following on your list at the top of this thread.
VD type 3hp at 1000 rpm. I have 3 of them, 2 K&L from 1939 & 1941 and 1 1937 Buzacott.
V type 3.5hp at 600 rpm. I have 3 of them, a Baltic, a Triumph & a Diabolo.
AK type 5hp at ??? rpm. I have 2 of them, a 1915 K&L & a 1916 Bartram.
BW type 3.5hp at ??? rpm. I have 1 of them, a 1915 Bartram.
KDA type 2.5hp at ??? rpm. I have 1 of them, a 1939 K&L.
KDB type 2.5ho at 1000 rpm. I have 1 of them, a 1940 K&L.
CL type 4hp at 1000 rpm. I have 1 of them, a 1946 K&L.
KE type 4hp at 1000 rpm. I have 1 of them, a 1939 Simplex Challenger.
Old 09-05-2019, 02:40:44 AM
The engines I listed are the ones for which I have little or no details, such as bore and stroke.
Information is available for most of those you list. Exceptions are the V type and CL type. I had not heard of these before. Do you happen to have photos?
As you have both a KDA and a KDB, have you noticed any differences between them? As far as I can tell, the only difference is the nameplate!
Eric
kelly and lewis petrol kero engine twin cylinder BillSteam Smokstak Down Under 0 04-03-2016 04:57:54 AM
Hornsbys by Kelly & Lewis EngineCrank Smokstak Down Under 1 11-18-2015 03:35:34 AM
Kelly & Lewis Truimph Engine Laringa4680 Smokstak Down Under 3 08-07-2013 07:46:07 PM
Dating Kelly & lewis Engines. SteamFire Smokstak Down Under 6 07-01-2010 06:39:16 AM
Kelly & Lewis 3.5hp cooler help needed john gilbert Smokstak Down Under 4 04-06-2010 05:02:41 AM
