Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Air Compressors
Air Compressors Restoration, Repair and use of Shop and Industrial Air Compressors
Air Compressors
Kellogg American 321 Compressor Pump cfm?
this thread has 6 replies and has been viewed 1307 times
Old 03-28-2018, 11:06:26 AM
skindaddy skindaddy is offline
Default Kellogg American 321 Compressor Pump cfm?
i have a pump number 321 compressor that was given to me, and before i put money into rebuilding it( even though i have it tore down) does anyone know how i can find out the cfm output of it? would like to see if it will meet my requirements! i've got a feeling its only around like 8 @ 90psi which wont be enough for the money i'm thinking.
it came with a 5hp 230v motor 1750 rpm, unit was altogether and running when received it, although had not run much in years.
was getting oil blow by into the lines.
Old 03-28-2018, 12:35:39 PM
K-Tron K-Tron is offline
Default Re: Kellogg American 321 Compressor Pump cfm?
The Kellogg 321 pump is a 2hp compressor, it has a maximum cfm rating of 8.8cfm @ 825rpm. If the 5hp motor was overspeeding that compressor, it may be too far gone to justify a rebuild. There are many more larger and better compressors out there. What sort of application are you looking to build a compressor for? I'd suggest looking into some older Quincy QR-25 series compressors. They are/have been the industrial workhorse for fifty plus years.
Chris
Old 03-28-2018, 01:17:49 PM
Vanman Vanman is offline
Check the motor pulley size to see how fast it was running. I'd bet they just stuck that 5 hp motor on it because they had it handy, and didn't actually change the pulley size. As long as it hasn't thrown a rod, it's probably fine?
I have a 5 hp 332 and a 10 hp 352 Kellogg and have been wanting a 321 for a very long time. It is very nice to have a smaller compressor for when not a lot of air is needed, that way your pump does not get ruined by condensation from not running long enough and thus not getting hot enough.
Check this link:
http://www.aircompeq.com/ka.htm
Old 03-28-2018, 01:24:20 PM
would the HP matter if it was still turning the correct rpm's? i actually dont know what they would be though. i also see ratings at 175psi too?
we just use it in our pole barn, impacts, grinders, on a rare occasion paint sprayer, alot of air blow nozzles. thinking would like something around 10cfm @ 90 or higher without blowing the bank.
yes if i completely rebuilt it rings,valve, 2 valves i broke, gaskets, rod bearings prob looking at about $150 to 175.
thanks again for the help
---------- Post added at 01:24:20 PM ---------- Previous post was at 01:20:01 PM ----------
oh also the one we have now i think puts out between 6 & 7 cfm and it is not enough for the impact alone you have to wait for air to increase for a minute at times.
next post
ok i will check pulley measurement tonight.
Old 03-28-2018, 03:08:00 PM
John Newman, Jr.'s Avatar
Long hose runs will severely limit / restrict air flow. My compressor is at the back of the shop and when I use an impact at the other end of the building, I had a noticeable drop off in performance. I added an aux tank at the front of the shop to maintain steady pressure and increase my total volume and have had no problems since.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 03-28-2018, 11:04:42 PM
ronm ronm is offline
Originally Posted by skindaddy View Post
[/COLOR]oh also the one we have now i think puts out between 6 & 7 cfm and it is not enough for the impact alone you have to wait for air to increase for a minute at times.
Use both of them. Set one to cut in at a little lower pressure than the other, you'll have 15 CFM if you need it, only the smaller one running if you're not using much air.
Smokstak member #442
Old 03-29-2018, 12:25:17 AM
That's a good idea, though I think I'd install manual controls to avoid running one of the pumps for only a short period.
The reason I say this is that I trashed the wrist pin bearing in the second stage cylinder on my Kellogg because, even with an 80 gallon tank, I wasn't typically running it hard enough to get it hot enough to avoid condensation in the second stage.
American Bosch PSB Pump Components Molinegb Antique Farm Tractors 8 02-27-2018 10:16:13 PM
American Jenbach Diesel Compressor DavidRaines Hit & Miss Gas Engine Discussion 7 07-04-2016 04:10:56 PM
American Kellogg 321 compressor EnginePat Machine Shop and Tool Talk 18 05-04-2015 02:50:16 AM
kellogg compressor pulley size no spark Machine Shop and Tool Talk 6 07-08-2012 07:00:33 PM
American Bosch pump Dean Allender Vintage Diesel and Oil Stationary Engines 2 07-08-2011 07:12:13 PM
