Smokstak Down Under
Early Fiat Tractor
this thread has 23 replies and has been viewed 2283 times
Old 04-08-2018, 04:36:25 AM
Nathan Woodruff Nathan Woodruff is offline
Default Early Fiat Tractor
Hi, Chasing a bit more info on this Fiat tractor, Looking for what model it is and engine and transmission details. I have been asked to look into finding out whether it is a viable restoration project for the museum that owns it. It has had some damage done to the motor with a sledge hammer but I am yet to have a decent look to see what has been busted.
ID:	307638   Click image for larger version
ID:	307639   Click image for larger version
ID:	307640   Click image for larger version
The Following User Says Thank You to Nathan Woodruff For This Post:
Old 04-08-2018, 04:46:43 AM
typak typak is offline
Default Re: early Fiat tractor
Its a 703, first built from 1924?.
The Following 5 Users Say Thank You to typak For This Post:
Old 04-09-2018, 01:56:18 AM
cobbadog cobbadog is offline
Default Re: Early Fiat Tractor
Looks like it is worth a go at restoration. Nice toy to have around anyways.
Old 04-09-2018, 03:31:22 AM
Craig Gillingham Craig Gillingham is offline
The serial number on these were stamped on a brass plate on the RH radiator side, on the RH crankcase and also on the RH side of the gearbox. If they're missing, the number is also stamped on the belt-pulley flange, where it bolts onto the rear transmission. Possibly also on top of the front axle, from memory. The serial number of the tractor is the last three digits. The first few numbers refer to the part (radiator, engine, etc.). The 703's were built at least from 1922, and possibly earlier than that. If the brass water pump and the carburettor are there, you're in luck, as they are hard to find. The rest looks good, and I'd say a lot of people would be happy to own it.
The Following User Says Thank You to Craig Gillingham For This Post:
Old 04-09-2018, 05:18:27 AM
I will have a look for the S/N Number next time I am there. I think from memory the water pump has been smashed with a sledge hammer but I think the carby is there. surprising all the tin work is fairly good just the engine has been taken to with a sledge hammer.
Old 08-08-2018, 06:14:40 AM
Update on the Fiat, Upon inspection a sledgehammer has been used to smash all the brass off it. This lead to the valve inspection bungs being smashed out taking with them chunks of the combustion chamber and shattered the water jacket. The damage to to severe to attempt any repair so this is an ask to see if by any random chance anyone would have a spare block or parts engine. I was wondering if the engine was used in any other fiat products. The rest of the tractor seems in fairly good condition such a shame the engine has taken such a beating they even tried to chisel the brass spinner off the crank handle but they have up on it. I will attach some pictures showing the damage. I would like to see what it should look like under the bonnet.
ID:	315937   Click image for larger version
ID:	315938   Click image for larger version
ID:	315939   Click image for larger version
The Following 4 Users Say Thank You to Nathan Woodruff For This Post:
Old 08-08-2018, 06:43:14 AM
Nathan, the top of that block isn't pretty.
The FIAT's used a lot of parts from the 18BL truck; things like the engine internals, and *I think* the transmission and diff have the same internals as the 18BL chain-drive transaxle. The blocks are slightly different, such as the carburettor mount, but they both used the governor that was internal to the block, and generally, they have the same layout. Whether an 18BL block will fit onto a 703 crankcase, I don't know.
The trouble is that the 18BL trucks are just as rare as the tractors, and I have a feeling the 18BL truck engine was based on the earlier Tipo 4, (possibly 5?) FIAT engine, and they are really-really rare, they stopped making them in 1918, and as far as I know, only one of those cars came to Australia. There were a lot more 18BL trucks come here.
Going by the I.D plate, it looks like your tractor is serial number 25 in the 703 production.
Old 08-08-2018, 06:55:44 AM
Yes I got the feeling it was going to be super rare and hard to find a spare block. Crying shame the damage that was done. Supposedly it was meant to be close to running condition when the museum first looked at it and when they went to pick it up some mongrel had smashed the hell out of it. Fabricating or casting a new one is out of the question due to budget restraints at the moment unfortunately. The S/N is 7230025. I wondered if it might have meant it was number 25. Do you know of many 703 Fiat's surviving in Australia?
Old 08-08-2018, 07:07:49 AM
Bloody vandals!
I agree I'm not too sure that block could be repaired, or even how you'd go about it? It's a shame, as the rest of the tractor looks good. I was chasing a wrecked FIAT 703 near Hopetoun about 5 years ago, however, it ended up being sold for scrap, sadly.
I'm pretty sure S/N is 7230025 means tractor 25, so unless there's one with a lower serial number, you may have the oldest FIAT tractor known.
I know of about a dozen 703's here and one 702. There are probably more early FIAT's here than anywhere else.
Old 08-08-2018, 07:15:56 AM
It is probably lucky that this Fiat did not end up going to scrap.
That is interesting if it is the oldest. It might be worth chasing up the cost of casting a new block if it is the oldest and also rather rare.
I would be interested to have a close look at a 703 they seem to be a well built tractor. Would also be interested to have a drive to see what they were like they are an interesting set up.
Regards,
Nathan
Old 08-08-2018, 08:51:44 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
You may need to expand your search to the home land where it was built. They were quite a bit more plentiful there, might just find a spare.
The Following 2 Users Say Thank You to FWurth For This Post:
Old 08-11-2018, 02:13:02 AM
Alastair Geddes. Alastair Geddes. is offline
maybe a good project to 3d scan and digitally replace the broken bits then 3d print a sand mould and get a new one cast.
https://3dprinting.com/3dprinters/s-...nter-by-exone/
Old 08-11-2018, 10:27:04 AM
FWurth's Avatar
One Millionth Post
I suppose it's a stupid question to ask, But did they save the broken bits? If the vandals were after the brass, possibly they left the broken cast lay? If the bits are still there, a real super good welder could piece it back? Just a thought.
Old 08-12-2018, 09:32:45 PM
Surprisingly enough nearly all the broken bits of cast are there but because it is broken through into the combustion space it would be a nightmare to weld up and then likely to blow apart when it fires. I would like to make up a pattern and cast a new one I have everything to machine it and that after but the budget is not there to be able to afford to do that unfortunately.
Although because of its rarity I am not that sure of what its value might be so it might be worth the investment?
Old 08-13-2018, 02:20:43 AM
You would think it would have a high value being such a rare tractor.
I cant remember which forum it was on but a very clever fella made 2 heads for a twin engine and out of steel being welded together piece by piece and built up to being very nice job. Obviously a heap of work but the outcome was perfect.
There are some very talented welders here as seen by some pics from the past and he is based in Sydney but cost of shipping and the time of an exceptional tradesman may put the stops on that.
Old 08-13-2018, 03:19:21 AM
I may have jumped the gun, saying it's possibly the oldest FIAT tractor. Thinking about it, the 702's were built a year or two earlier in 1918-19, sorry, and there are probably older FIAT tractors.
The un-restored 703 FIAT that sold at the Bookham auction at the end of last year made over $20K. I still think they are a very worthy tractor of restoring.
Old 08-13-2018, 05:13:52 AM
Must be fairly desirable as I thought the one a Bookham looked rough although I did not get to the sale to see it in person. I did think you only meant the earliest in the 703 series.
They truly are an unique piece of kit with some interesting features. It would appear that the crank handle goes through the bottom tank of the radiator as it has a gland on it.
Old 08-13-2018, 09:30:55 AM
Peter Short Peter Short is offline
I have seen some remarkable weld repairs made by "sunshine man" posted on the TOMM forum.
For example: https://forums.tomm.com.au/index.php....html#msg26121
The Following User Says Thank You to Peter Short For This Post:
Old 08-13-2018, 11:52:26 AM
FWurth's Avatar
One Millionth Post
Can't get any pictures on that here, must have something to do with not being registered on that forum. I believe that if it was me, I would get in touch with that fellow and chat a bit. Couldn't hurt.
Old 08-14-2018, 02:06:51 AM
Those images came up after clicking the link and then going back up the page to view the superb workmanship.
There are a couple of Fiat tractor spares specialists here in Oz but it would be a long shot.
Fiat 702 Tractor Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 36 08-02-2019 10:33:54 PM
Early tractor? Russ Hamm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 23 07-24-2015 08:43:18 AM
Fiat 880-5 and 980 Danielrooi Antique Farm Tractors 2 05-27-2014 03:19:29 PM
Fiat 880-5 and 980 Danielrooi Vintage Diesel and Oil Stationary Engines 0 05-20-2014 02:03:22 PM
Early Gas Tractor Ads Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 17 03-01-2011 10:11:13 PM
