Smokstak Down Under
Austral Otis Wilfley Concentrator?
this thread has 14 replies and has been viewed 1442 times
Old 07-26-2018, 03:45:42 AM
typak typak is offline
Default Austral Otis Wilfley Concentrator?
Some pictures of a Wilfley table I'm uncovering at the moment from under years of accumulated detritus, appears that the vertical belt from the line shaft beyond the jackpump powers it, just when did Austral Otis manufacture this style of Wilfley?, also what make of pump?
ID:	314932   Click image for larger version
ID:	314933   Click image for larger version
ID:	314934   Click image for larger version
The Following 3 Users Say Thank You to typak For This Post:
Old 07-26-2018, 07:33:52 AM
Paul Richardson Paul Richardson is offline
Default Re: Austral Otis Wilfley Concentrator ?
What breed is the engine Kim that is direct coupled in the last pic...?,.there's a nice looking curved spoke flywheel looking kind of incidental over at the bottom left hand of the picture .
The Following User Says Thank You to Paul Richardson For This Post:
Old 07-26-2018, 09:22:12 AM
davob davob is offline
My guess is it woud be one of the engines in this thread being that a Wiffley Table is used in ore processing.
https://www.smokstak.com/forum/showthread.php?t=179178
The Following 3 Users Say Thank You to davob For This Post:
Old 07-26-2018, 04:25:50 PM
Default Re: Austral Otis Wilfley Concentrator?
The flywheel looks quite slender in build but I'm guessing that's the Crossley having twin flywheels?A veritable gold mine!
I wonder what year Kim,..pre 1910 at least?,closer to 1900?
The Following 3 Users Say Thank You to Paul Richardson For This Post:
Old 07-27-2018, 07:27:11 AM
Hi Paul, not exactly direct coupled as it has a lever operated dog clutch that is between the carrier bearing on the plinth and the crank, the large pulley works the water pump the small on the Mort's stamper battery, engine was dispatched? September 1910 for agents Alex Cowan & Sons Sydney.
ID:	315008   Click image for larger version
ID:	315009   Click image for larger version
ID:	315010   Click image for larger version
Name:	Austral Otis 1902.png
Old 07-27-2018, 08:34:11 AM
That was actually a half decent guess on my first try!,..i surprised myself.
I'm studying the pics pretty hard,..but still not sure on size and fuel?I will have a crack at M size or a touch bigger?,..and wondering if some of the double letter models carried a high speed governor?
All in good time I suppose?The old pole shed looks like a real treasure trove!
The Following 2 Users Say Thank You to Paul Richardson For This Post:
Old 07-27-2018, 07:29:51 PM
Purely a guess on the pump Kim,but if I was asking myself what Melbourne manufacturer the crown gears reminded me of I would be quick to say Macson.
It's quite a similar tapered oval section in the 6 spokes that are commonly seen on Macson machinery,pump gears and pulleys,lathe change gears etc.
Old 07-29-2018, 06:18:42 PM
Hi Paul, could well be a McPherson's pump? a better pic of the pump, also the starting/idler engine for the main engine, a bit of work here to get the old gold battery up and running, also the old pole shed is well overdue for some maintenance and will get some new turpentine and brush box poles where needed and a few sheets of Orb roofing iron.
ID:	315204   Click image for larger version
ID:	315205   Click image for larger version
ID:	315206   Click image for larger version
The Following User Says Thank You to typak For This Post:
Old 07-29-2018, 07:44:49 PM
The three bolt sidebolt windmill pump might be Southern Cross at a guess?
Old 07-30-2018, 03:38:00 AM
Darryl Darryl is offline
Originally Posted by typak View Post
Hi Paul, could well be a McPherson's pump? a better pic of the pump, also the starting/idler engine for the main engine.
Be easier to hand start the Crossley and use that to start the Sunshine.
The Following 2 Users Say Thank You to Darryl For This Post:
Old 07-30-2018, 07:41:32 AM
Hi Darryl, don't Sunshine two stroke engines start easily? the Crossley gas engine has 5' x 4'' flywheels so is a reasonable size and is converted for petrol so could be a little cranky to start? the badge on the Sunshine, Cameron, Sutherland and Seward I can not recollect seeing on another engine? also what was the 'Riverside' oil engine?
ID:	315247   Click image for larger version
Old 07-30-2018, 09:53:50 AM
Peter Short Peter Short is offline
I wondered about the nice fluted cast iron pillar seen in the first post...looked a bit out of place - its a roller door!
Otherwise, what a great shed and set-up of machinery!
The Following User Says Thank You to Peter Short For This Post:
Old 07-30-2018, 06:17:08 PM
Very interesting ! Day's pumps and Riverside pumps were, i thought, two seperate pump companies but surely if Riverside was seperate then they'd use one of there own pumps on there Riverside engine (re badged ? ) adds.
I have a couple of Day's pumps but never seen a Riverside in this district.
PS. What the hell is a " concentrator" anyway ?
Old 07-30-2018, 08:27:38 PM
Wilfley concentrator is a oscillating table with ripples that concentrate, in this case gold slurry, into a richer concentrated form, separate the wheat from the chaff so to speak, a table working here in this video at about 2.50.
https://www.youtube.com/watch?v=wAUbdqs8Xy4
The Following 2 Users Say Thank You to typak For This Post:
Old 07-31-2018, 04:15:45 AM
Good video typac. Tangye has a bent crank , i wonder what happened to it.
OTIS no 3 Babbit Brian.P Hit & Miss Gas Engine Discussion 2 02-14-2018 06:14:41 PM
1888 Baldwin engines made by Otis Brothers Wayne Grenning Hit & Miss Gas Engine Discussion 13 03-15-2016 06:49:31 PM
Otis Ks tractor auction June 4-5 Meco3hp Live Auctions of Engines, Tractors and Old Iron 0 05-13-2011 11:10:03 PM
Otis & Frances Astle Auction, Oxford, PA, some of everything Jim Anderson Live Auctions of Engines, Tractors and Old Iron 26 05-16-2010 06:29:43 PM
Otis Old Iron Days, Otis, Ks. Show report 2010 Meco3hp Hit & Miss Gas Engine Discussion 5 04-26-2010 01:37:33 PM
